FTO Rim sizes
- Timnkoo
FTO Rim sizes
Hi guys,
Firstly I apologise for the repost....im sure this has been covered a few times but i cannot find the posts on rim sizes anywhere (the search fucntion either isnt working or is REALLY poor).
Basically I would just like to know what rim sizes those on 17"s have. Like dimensions/star pattern etc etc and what WILL fit on an FTO before rubbing/lowing suspension needs to take place. i do not plan to lower the car but would like 17" to go on. Any feedback on what you guys are riding on would be great.
Thanks
Thanks
- FTO338
PCD is 5x114.3, for 17" you can either go for 17x7 or 17x7.5, you might have problem with 17x8, but that depends on which offset you pick.
Offset is from 35+ to 45+
Tyres you can use from 205/45/R17 to 225/45/R17, once again you can go higher profiles or wider tyres but it might rub depends on the offset of your wheels
BTW which seach button did you use, the one on the left of the screen or the on the top??
- Supplanter
- Timnkoo
Yeah the search up the top is fine...i was trying the one on the left.....anyway back to tires...
Does anyone think if I go a 17" with 45 tyre it will look like a 4WD? Would it be too high and would I notice a lose in handling performance? Also would a 40 or 45 profile be better for me considering I'm not planning on lowing the car?
Thanks
Thanks
- FTO338
Noise is really depend on the thread pattern & the compound they use on the tyres.
Since you not going to lower the car, I suggest either 45 or 50 profiles as it will be more comfortable then the 40. But like i said, you have to match it with your offset.
- FTO338
Yes thats why i said 35+ to 45+ and not 35+ & 45+mr_bishi wrote:The correct offset for the fto is +38 not 35 or 45 (although others will fit)
Yes,but it's not 35 to 45....its 38! Not 37,not 39 not 38 ish but 38. Other sizes will physically fit but they will be incorrectFTO338 wrote:Yes thats why i said 35+ to 45+ and not 35+ & 45+mr_bishi wrote:The correct offset for the fto is +38 not 35 or 45 (although others will fit)
- FTO338
I don't see the problem of giving options for members when they are looking rims, & the rims he or she want might not have exact 38+ offset.
Is like saying the FTO rims is 16" so therefore you have to get 16"
You pommy picky bastard
- khunjeng
- FTO338
Here you go mate, its got pics & all. heheehhe
http://www.tirerack.com/wheels/tech/tec ... techid=101
FTO338 wrote: You pommy picky bastard![]()
I know!
Offset is fairly important as if incorrect it increases bump steer and tramling as the steering isn't turning on the same axis anymore....So i thought it would be best to make owners aware rather than them wondering why the car has become 'skitty' in a straight line and behaves differently cornering.Also,if you go +45 Your rims will be nearer the suspension so you won't be able to go so wide as you may like,or your wheels will sit further in the arches and they'll look odd. I'm actually running +45 with 6mm spacers bringing it to +39.
Don't take me personally!!
- FTO338
Nah man, is all good. I'm a half pommy until last yr when my pommy passport expired heheheehe so theres no way i get offenedmr_bishi wrote: Don't take me personally!!
- AERODYNAMIST
- FTO338
Not a chanceAERODYNAMIST wrote:well i am planning to buy an 18 inch rim with 9.5inch wide at the back and 8.5 inch wide front....will that fit??
- AERODYNAMIST
- FTO338
7.5" would be ideal, I know there are members here who got 18x8, but unless the guy who doing the package for you really know what his doing, if not then you going to get some rub with anything wider then 7.5â€
