Timing Belt Kit
Timing Belt Kit
Is the best place to buy a full timing belt kit (including hydraulic tensioner) on Ebay (Dayco) for $319? Or can I get a better price elsewhere?
[edit] just noticed the previous post to mine tonight as also about timing belts. What are the odds....[/edit]
    Re: Timing Belt Kit
    The eBay guy mitsfix is aussie, they have a Facebook page too so u can chat with them
    yotka
    Re: Timing Belt Kit
    Post by yotka »
    Which kit are you looking at? the 087H, or the one I mentioned in the previous thread?
    Re: Timing Belt Kit
    This:
    http://www.ebay.com.au/itm/DAYCO-TIMING ... SwmrlUxdvx
    Has the hydraulic tensioner in it as well supposedly. Its the 292H. Hadnt checked the teeth count. Was going on face value
      Re: Timing Belt Kit
      Well with the GBP dropping. Might we worth seeing if viamoto is a viable option.
      Re: Timing Belt Kit
      Too Expensive unfortunately
        Re: Timing Belt Kit
        The misfix guy will sort you out, also have u tried supercheap auto parts guide. I got all my cam,crank, rocker cover seals from there
        yotka
        Re: Timing Belt Kit
        Post by yotka »
        Is your car a GPX?
        Do you still have your receipts for those?
        Trouble with their system is that, you are not really sure if you are getting the right stuff, as in for Mivec, or non-mivec.
        Re: Timing Belt Kit
        Dwayne, I've heard some pretty bad stories about non OEM tensioners.
        NTN are the suppliers of OEM hydraulic tensioners from what I understand so you're better off buying a kit without it and sourcing an NTN tensioner separately
        Re: Timing Belt Kit
        The mitsfix guy knows his sh*t, and yes I bought a whole kit from him for a mivec. He knows about the tooth difference.
        mezje
        Re: Timing Belt Kit
        Post by mezje »
        I know Mal from MitsFix, the guy is a f**king legend and knows so much about Mitsus it is crazy. If you call up and ask or send an email he will answer with detail.
        Re: Timing Belt Kit
        So is Mitsfix one of the mobs on Ebay or somewhere else?
          mezje
          Re: Timing Belt Kit
          Post by mezje »
          dstocks wrote:So is Mitsfix one of the mobs on Ebay or somewhere else?
          MitsFix have an eBay store called mitsfix, they also run a shop down here under the exact same name where the parts are shipped from.
