ENGINE PROBLEMS
adzski
ENGINE PROBLEMS
Post by adzski »
hey guys,
looking for a bit of mechanical guidance
so the other day my car shut off while i was driving, and wouldn't start.
i didn't hear any knocking sounds or bangs.
I am slightly concerned it may be a mechanical issue? if the engine blew, would i hear a knocking or something similar when i try to crank it?
it try's to crank and all most gets there but doesn't turn over.
I haven't had the time to check error codes yet, as i have exams.
Id say its a electrical issue, will look further into that after exams, but just wanting to know if there is a dead give a way of internal issues that i could look for?
Cheers
adzski
Re: ENGINE PROBLEMS
First thing to do is check codes. If no codes, check if you're getting fuel and spark.
Re: ENGINE PROBLEMS
Check basics. Battery terminals, do you have petrol and oil, etc.
Re: ENGINE PROBLEMS
Acc belt broken and took out your crank position sensor wiring
adzski
Re: ENGINE PROBLEMS
Post by adzski »
PHIL069 wrote:Acc belt broken and took out your crank position sensor wiring
nah not this time, thats what happened last time. was the first thing i checked hahah
adzski
Re: ENGINE PROBLEMS
Post by adzski »
checked codes
got 12 and 13
12 Air Flow Sensor
13 Intake air temperature sensor
so do i just change my maf sensor?
Re: ENGINE PROBLEMS
Make sure they're plugged in properly to start with...
adzski
Re: ENGINE PROBLEMS
Post by adzski »
changed the maf, still cranks no start.
Checked codes again, no codes, just constant flashing.
What should i check?
adzski
Re: ENGINE PROBLEMS
Post by adzski »
ill check spark.
Re: ENGINE PROBLEMS
Pull out your ignition leads, see if there is a spark, if no spark then it's ignition related. Could possibly be an issue with your fuel lines/fuel pump?
Re: ENGINE PROBLEMS
Also get a volt meter and check your battery
adzski
Re: ENGINE PROBLEMS
Post by adzski »
Checked there is no spark.
Also sprayed carry cleaner in intake, so i defiantly know that its not fuel related.
could it be the ignition failure sensor?
Re: ENGINE PROBLEMS
Possibly. Did you end up pulling the error codes?
adzski
Re: ENGINE PROBLEMS
Post by adzski »
no codes.
adzski
Re: ENGINE PROBLEMS
Post by adzski »
also when i crank the car, the rpm don't move?
adzski
Re: ENGINE PROBLEMS
Post by adzski »
changed the ifs, still not start and still no rpm?
Re: ENGINE PROBLEMS
RPM won't show until it starts up.
adzski
Re: ENGINE PROBLEMS
Post by adzski »
i thought it would move little bit maybe like 200-300 rpm. anyway i might just take it to a auto elec.
Re: ENGINE PROBLEMS
Nope, doesn't move at all.
yotka
Re: ENGINE PROBLEMS
Post by yotka »
Do you have an immobiliser?
If engine shuts you off while driving, could be due to it.
I had something similiar.
Something about the relay being worn, and de-magnetised, and cut the engine off, when running.
