Seat Bracket front left bolt snapped
- illmotion
As the title says on the front left passenger side
what can i do to fix it?! the bolt snapped while i was undoing the nut now it just flat off with the surface, i have looked at blind bolts, blind nut rivet but i don't know if they a the right size and what should i do to fix this problem?
Thanks
Thanks
Re: Seat Bracket front left bolt snapped
Centrepunch it, small drill bits and an easyout
- illmotion
I think the screw might be welded to a body frame at the bottom? Correct me if I am wrongsilverGPX wrote:Centrepunch it, small drill bits and an easyout
- Supplanter
Front of the seat uses bolts, the back has bolts fixed to the floor pointing up.
- illmotion
Weird the part that snap off had a nut attached to it and the other ones had a circle tip and it a bolt that screws down.
How would I fix the fixed bolt from the floor pointing up?
- Supplanter
- illmotion
Is it accessible under the carpet?Supplanter wrote:Weld a new one in?
- vipfto
this
Completely wrong actually.The other way round. In the front, the bolt threads are welded to the floor pan. Nuts are used to hold the seat down. On the rear, the holes are in the floor pan and bolts hold the rear of the seats down.Front of the seat uses bolts, the back has bolts fixed to the floor pointing up.
Sorry, other way around.Supplanter wrote:Front of the seat uses bolts, the back has bolts fixed to the floor pointing up.
Front = welded bolts sticking up (studs), you put the nuts on.
Rear = bolts used to hold down seat, you put the bolts in.
Best pics I got at the moment, taken when I sprayed my FTO...illmotion wrote:Is it accessible under the carpet?
I was 30 seconds too late
Hey dstocks, you wrote your post while I was uploading my pics
- illmotion
Thanks for the photos but I think I am blind lol cannot spot it
Missed it by that much.......I was 30 seconds too late
They're hard too see as it's all red
I have circled the 2 studs viewable in the pic...
From the "Body Repair Manual", each arrow is pointing to a front seat stud...
- illmotion
Ahhh there we go much easier to see
well I don't have a single clue how to get under there looks like it welded down
- Supplanter
