It exists, a MIVEC 6A13 2.5L Twin Turbo FTO
- spetz
It appears this has already been done.
It seems genuine too as the heads are obviously MIVEC, and the intake manifold is from a 6A13TT.
Also it makes mention of how the heads are 2cm higher making a FRP hood necessary.
Can anyone tell the age of the page?
And, if there is any way to contact the workshop?
http://translate.google.com/translate?s ... %2F29.html
Re: It exists, a MIVEC 6A13 2.5L Twin Turbo FTO
Well, the wayback machine goes to 2010 with a snapshot.
That's the oldest record of the page.
![Image](http://www.completervr.com/nxc/Astronboy8.gif)
I've seen it done a few times, but I can't remember where I saw it....
Here is a page from RPW with a mivec 6a13
http://web.archive.org/web/200609100128 ... &Itemid=40
- Kustom
6a13 has been done heaps? I'm a little lost...?
![Image](http://i219.photobucket.com/albums/cc167/stefisleet/untz2.png)
He's talking about A 6a13 with mivec heads from a 6a12 retard!Kustom wrote:6a13 has been done heaps? I'm a little lost...?
- Kustom
So he is! Knew I was missing something... I kinda gen y'd the postSahin wrote:He's talking about A 6a13 with mivec heads from a 6a12 retard!Kustom wrote:6a13 has been done heaps? I'm a little lost...?
At least you actually are Gen YKustom wrote:So he is! Knew I was missing something... I kinda gen y'd the postSahin wrote:He's talking about A 6a13 with mivec heads from a 6a12 retard!Kustom wrote:6a13 has been done heaps? I'm a little lost...?
- spetz
You've actually "seen" this done or heard of people thinking about it?Technikhaus wrote:I've seen it done a few times, but I can't remember where I saw it....
This is the first I see it done, and the RPW hybrid motor was never finished off so it does not count.
I've seen photos of it done before, but I can't remember where,...
- spetz
Are you sure you're not making some mistake?
The link above is the first I've ever heard/seen of it, and I've been searching for a while now
Definitely not a mistake, I just can't remember where I saw it.
Good find Spetz.
I was under the impression that mivec isn't good/wouldn't be good (like you lose power) for boosted applications on our engines (including 6A13) due to exhaust overlap or something or is that with the standard mivec cams and getting a different grind and vernier cam gears are required to gain from it?
(don't really know i'm just regurgitating what i've read or heard in the past which may be rubbish)
- spetz
Technikhaus, if you do find it or remember anything about it please do post it up here.
Rob, I do not know for sure but yes the cams would likely not be best for boosted applications.
But, if you use custom cam specs for turbo you could have one profile to spool the turbo fast, or have good torque before boost, and the second profile for flawless top end power.
I think at the same time because in a boosted application you would want less duration (for less overlap) that you can grind down the MIVEC cams without having to pay for new blanks
Sounds interesting, may be worth me looking into cams then when i've exhausted all other options as i'm still using mivec in my supercharged setup (and when i've got loads of spare money to throw at it too).
So who's going to try doing this hybrid then?
lol, there's the project killer... 'custom cam specs'
Yeah and I know nothing about cams except they go round and round and make noises.Bennoz wrote:lol, there's the project killer... 'custom cam specs'
I bet there's a bit of a science behind custom cams and a fair bit of risk too or is it simply that an experienced engineer armed with engine specs and good maths can work it all out?
- spetz
To be honest I was expecting a bit more excitement over this.
I've considered/wanted to build this motor. But it's the cost of it and at the end it won't be worth 1/10th of what you put into it, plus for that kind of money today there are pretty enticing options.
There's the cheap option too, of OEM bottom end, stock cams etc, but it seems like such a half measure, and maybe modifying the 6A12 is a better option at this stage.
- ZFL45H1
What is actually involved in this though I thought the hardest part was just the timing belt but once thats sourced it wouldn't be that bad would it (I'm assuming it is though cause if that's all it was I'm sure a lot more people would have done it)
Mate its cost me 20 grand just to get a regular 6A13 working right, I'd hate to think what it would of cost to rip the motor apart as well. I've got another 6A13 here at thome that I'm rebuilding with forgies, but I'm doing it slowly over time as funds allow. Purely to replace the one that's currently in the car, cause putting 18 pound through it all day everyday isn't exactly good for its lifespan.spetz wrote:To be honest I was expecting a bit more excitement over this.
Plus all this sh*t is getting old news for me. I earn enough these days to be able to go & buy a 300kw car off the shelf. I got real tired of going to & from a workshop for 2 years & throwing spanners at my mechanics as they fucked up time & time again, resulting in me doing half the work.
