Wrecking whole car
Wrecking whole car
Ok guys & gals, time to pop the rest of this wreck up for sale :)
I've got some 'featured items' pictured here, the rest - just flick me a pm ;)
Light up kick plates $150. Usualy wear & tear for their age. Comes with all wiring & plugs.
*Mint Condition* Mivec engine cover. Make me an offer.
Crossmember with 2 x perfectly good solid lower engine mounts $60
DC lip compliments of Subby. Needs a little bit of fibre glass repair underneath (bottom out wear thin) but otherwise ok, make an offer.
(Proceeds to be used at Syd FTO xmas party tab)
Faux woodgrain tip cover! :lol: Make an offer (beer would be acceptable)
Stock air box. Make an offer.
Gen Mitsi oil temp gauge. $40
Climate control unit with surround (vents etc) $60
SCA brand (aka Super Cheap Auto) generic gear nob $15
Driver side tailight, pretty much mint condition $100
Passenger tail light, has 6-7cm crack through centre of it (still water tight) $50
Rear wiper assembly. Can come with loom, rear windscreen & rear parcel tray to suit if need be. Make an offer.
Indicator assembly. Rear wiper version $75.
Reconditioned headlights. No cracks, no internal fractures or anything. $125 per side, $220 for the pair.
Anything else you can think of, the car probably still has it in it. Full interior with seats etc, engine, suspension, the works...
Re: Wrecking whole car
How the f**k does a car with a 180K km engine have a mint condition Mivec cover on it? :lol:
U sure that's the original engine? Have you checked the engine number against the VIN plate?
Shane001 wrote:How the f**k does a car with a 180K km engine have a mint condition Mivec cover on it? :lol:
you sure that's the original engine? Have you checked the engine number against the VIN plate?
You know how its possible? By not f**king around & trying to modify the c**t of thing!!! :lol: All this car got was serviced!!!
Forgot to mention other bits!!
GPX alternator $150
AC compressor $100
PS Pump $75
Radiator with fans $125 (manual version)
I'm thinking about the Mivec engine cover.
If it's still around in a week I will put a bid on it :D .
What condition are the front seats in and how much each? (My drivers side is falling apart..)
I wouldn't mind the oil temp guage actually if the sensor is included (or is it ecu tapped already?)
Meanwhile, c*** of a thing getting the centre piece off to install it :roll:
Edit: also might just add to your post Bennoz for a slight correction, those mounts were for manual, as we discussed. Otherwise you wouldn't still have it :lol:
Also interested in the oil temp gauge.
phi-tec
Post by phi-tec »
hey bennoz whats the condition of the alternator? i need a new one, how much would postage be to brisbane? need to consider my options :?
phi-tec wrote:hey bennoz whats the condition of the alternator? i need a new one, how much would postage be to brisbane? need to consider my options :?
Well, it has done 180,000kms, so it might be worth throwing a new set of bushes in while its out. Having said that, it was working perfectly when I drove it 2 weeks ago.
Postage to Brissy for something around that weight would be about $30 bucks I'd reckon.
bass_twitch wrote:What condition are the front seats in and how much each? (My drivers side is falling apart..)
Passenger is in good nick, drivers has the usual wear on the bolster, no holes, but a bit soggy to touch. Welcome to come have a look.
Astron_Boy wrote:I wouldn't mind the oil temp guage actually if the sensor is included (or is it ecu tapped already?)
Its the Mitsi sump plug sender with the wire hanging off.
Wrecking whole car
just wondering, would the passenger side fit instead of my drivers side? Is there any difference in them? (or in installation?)
LOL cant be done, tried it.
Wrecking whole car
dammit! It was worth a shot...
Eltnot
Post by Eltnot »
Does it have the controls for electric folding mirrors. My switch to folder them in is a bit stuffed, so wouldn't mind a replacement.
Eltnot wrote:Does it have the controls for electric folding mirrors. My switch to folder them in is a bit stuffed, so wouldn't mind a replacement.
Yup. Hows 10 bucks plus postage?
Bennoz wrote:Its the Mitsi sump plug sender with the wire hanging off.
Hmmm. So I take it, I'd have to get a bung put in to my sump?
8O I hope that not a euphemism...
No, the sump plug is the sender. Wire hanging out of it etc ;)
Can you take a pic of the sump plug please ;)
I'll take it if Astron Boy doesn't, would be useful in the racecar :)
Shane001 wrote:Can you take a pic of the sump plug please ;)
I posted right after Astron Boy that I was interested in it. :lol:
:lol: no worries
