Not really a help thing just a question.
- aza013
- NSW Coordinator
Ok just a question, would an earth problem make the car loss kw power?
Re: Not really a help thing just a question.
Possibly. Not enough spark getting delivered..
- aza013
- NSW Coordinator
Mmm interesting
I wonder if that was my problem then with my kw power loss due to bad earth of the battery.
Will have to change out the fuel filter and get it back on the dyno
- SchumieFan
lol
i badly need an earthing kit, but they look so ugly
- bass_twitch
Hey aza when are you planning on doing your fuel filter? Let me know and if I'm free I'll come and do mine at the same time? (and you can provide useful advice/assistance? haha)aza013 wrote:Mmm interesting
If your battery wasn't in the boot Aza, I have a heap of short runs of 8GA we could have put all through your engine bay for extra earthing...
Might still work off the terminal in your bay, but ultimately straight off the battery is the way to go.
- aza013
- NSW Coordinator
I will be looking into getting more earths of the battery put in.
- bduffman
first thing i did when i got the fto was swap out the battery with blue top and put two 2g grounds from batery to engine ( prob should upgrand engine to chassis )
was playing around the other night and the engine ground wasnt connected to chassis and boot leds didnt work , then placed them to the engine and worked took one off and light dimed
grounds are just as important as power wires ,
seeings your battery is in the boot how did you wire it up
ground battery to chassis in boot or did you run wires to the front to the engine
if you grounded to chassis then you prob should upgrade engine to chassis
- aza013
- NSW Coordinator
The battery is grounded in the boot and the engine bay earth has been mounted the the frame of the car. So the earth use the car to connect each other.bduffman wrote:
- bduffman
yea thats how i had the old corolla set up
what size power and grounds are you running
- aza013
- NSW Coordinator
F*#*ing big
- bduffman
fair enough i was running 0g power to front and 1 0g ground 1 2g ground and 2 8g grounds ( was using the 2 and 8s for amps
