Need NEW: GRRR
Need NEW: GRRR
Front, rear engine mounts
timing belt
cam seals
Car is still making that grinding/ swooshing... something sound from the front right wheel.
Had the shafts done, had the bearings done, had the steering rack checked.............. WTF is it???
F anr Rear mounts just get rebuilt with new bush
Prob have but Have you checked over brakes?
brakes are fine, plenty of pad, rotors arent warped.
doesn't feel like the calipers are sticking.
oh, also forgot, the cross member has a kink in it, cars been bottomed out at one point :roll:
was thinking of getting solid front and rear mounts, just because I am sick of going through mounts on Mitsus
could be tyre noise.... are they still round no scalloping?
heaps of tread, and they're round.
certainly doesnt sound like a tyre noise though.
Mechanic at one point thought it was piston slap as it does it under load and in the rpm range, but it doesnt do it when you turn right, only when you turn left. Or have any small degree of left steer.
have new tyres going on this weekend hopefully.
and I'll put the old rvr pads on for now, see if that does anything.
F'ing annoying this.
possibly in the actual rack.....
hmmmmmmm, there's no leaks
and had it checked, it all seemed ok, had the boots replaced.
I can get you a poly lower rear mount if you like. Need an old one to make it from thou, they cost about $180.
Bennoz wrote:I can get you a poly lower rear mount if you like. Need an old one to make it from thou, they cost about $180.
Might take you up on that.
Currently mine isnt a mount, its a hole with a bolt sitting in the bottom of said hole.
Didn't really look, but do the mounts bolt to the engine or the gearbox?
If gearbox I'll have to remove mine due to I'm sure it being different than a 4spd or manual.
They bolt to the box. The bracketry is the same across the range thou. To get it out, you just need to drop the cross member off.
DIY: http://www.ftoaustralia.com/modules.php ... ebd39e82bf
Re: Need NEW: GRRR
Astron_Boy wrote:Car is still making that grinding/ swooshing... something sound from the front right wheel.
Hate to sound like captain obvious, but is it perchance, the brake dust gaurd rubbing against the back of the disc? On full lock, it can be bent by contact with the lower control arm & pushed against the disc.... been down that road before.
Re: Need NEW: GRRR
First thing I checked Captain Obvious. :P
sadly it wasn't it, which is why I began this whole journey into wasting money fixing a noise :evil:
Yeah, I know about needing to drop the cross member, honestly not happy doing that as the cross member is warped/ bent, and looks like one of the bolts is misaligned and ready to snap off if I remove it 8O
Don't want to pay a mech to do it, but don't want to do it myself for fear of f**king something.
Same goes for the belt and cam seals
