Bad consumption
wildfaye
Bad consumption
Post by wildfaye »
Hi all, I drive a 2.0Mivec FTO. Experiencing not so good fuel economy.
Driving habits are 70% highway and 30% city. Have not changed driving habits for 6 years.
When the car was new(6yrs ago) could get 10km/l, wacking with mivec can get 9.5km/l.
typical fuel rates are as follows:
3/4full 200km. 1/2full 300km, 1/4full 450km. can left 1/8full tank at 550km than top up.
now can onli get 8.5km/l, with mivec wacking can onli get 8km/l.
3/4full 130km. 1/2full 200km, 1/4full 330km. can left 1/8full tank at 400 than must top up liao.
Can anyone help? Very fustrated. now done dare to mivec e car liao, too expensive on e wallet. I am sure the amount of money to get to rectify the fault is definitely cheaper than the cumalative EXTRA money spend on petrol the last 2-3 years.
The car is stock, even wheels. now just did 100k timing belt service and all related stuff.
Thanks all in advance for any advice!
Cheers!
Sam
I am in Singapore, BTW.
GPXXX
Post by GPXXX »
<insert singaporean/malay accent here>
"eh, maybe you are using a dodgy batch of fuel-leh? :roll:
does the fuel warning light come on when you get to 400kms?
i'm starting to get similar problems liao, although nowhere near as bad as you larrr... :?
have u had any extra passengers in the car lately? more passengers = more weight, hence more power needed to carry the weight around mah...
also if you use your aircon regularly and your tyres are not running the right pressure, it can also affect your fuel consumption one so be careful lorrr..."
FTO338
Post by FTO338 »
When was the last time you clean your injectors? Change your petrol filter?
jeremywe
Post by jeremywe »
eh... you all from singapore one ah?
GPXXX
Post by GPXXX »
jeremywe wrote:eh... you all from singapore one ah?
no larrr, but close enough... ;) *hint*
there's actually quite a number of S'poreans here, ie: Jono, Eric (SBE8888), Sam (wildfaye) just to name a few...
smorison
The Godfather
Post by smorison »
omg don't say that... last time i was in singapore they had just released a song called something like "just say larrr" and i bet you can guess the lyrics... :P
took months to get it out of my head...........
back onto the topic... so many possibilities i would consider:
injectors
transmission oil (how old is it?)
engine oil (do you service regularly still?)
does the car run rich??? (could be an O2 sensor)
umm.... there are some starting points
GPXXX
Post by GPXXX »
smorison wrote: omg don't say that... last time i was in singapore they had just released a song called something like "just say larrr" and i bet you can guess the lyrics... :P
hmm no lehh, can't say i've heard of it... :roll: ehh, how does it go one? ;):P
ROFL... :lol:
smorison
The Godfather
Post by smorison »
GPXXX wrote: hmm no lehh, can't say i've heard of it... :roll: ehh, how does it go one? ;):P
ROFL... :lol:
its about 3 words repeated over and over and over and over and over and over and over .... and over
just say larr
btw is the lahh or larr??? could never work out how to write it
jeremywe
Post by jeremywe »
Its LAH. (never heard of the "juz say lah" song... you sure it was from sgp?)
Anyway, any sgp fto owners in brissie?
GPXXX
Post by GPXXX »
OMG just realised we are sooo way off topic LoL... :lol:
quick, everybody get back to the topic before "you-know-who" goes down on you like a tonne of bricks! :twisted: :P
Guni_GuGu
Post by Guni_GuGu »
Not sure, if it makes any different, or if your not using it alrdy, but you should be using priemium petrol, about as cloose to 100octane as you can get... I think all premium is 95, but shell optimax is 98? with an addetivie, you could get that closer to 100...
but I think they did some research on these boards, and showed the addedtive didn't really help out at all....
wildfaye
Post by wildfaye »
Let the original speak for himself.
AHEM: Wah Lau Eh....
Okie, my car runs the aircon daily, jesus the weather here suxx.
Max of 2 pple in the car all the time. Only load is 2 umbrellas and 1 street directory. No ICE.
Tyre pressures are stock as recommended.
Used to get the fuel lamp on at ard 480kms, now 360kms
No one sells dodgy fuel in Singapore.
Have already cleaned throttle body and injectors, all filters in the car have been changed. All fluids have been flushed.
Runs on esso-mobil 8000(octane 98).
Runs on mobil 1 super syn 5w50.
I duno if the car runs rich, but i smell some petrol outside sumtimes.
How do I check the O2 sensor and how does it work? Is it expensive to repair/replace?
Any more suggestions or info needed?
I reckon the amount of extra money spend on petrol weekly is more than sufficient to give me a reasonable yield on better consumption, if i were to spend it on rectifying this fault.
Sam
smorison
The Godfather
Post by smorison »
ok i'm at a loss as to what the problem is... its obvious the car has been properly maintained....
O2 sensors here are in the 250-300 mark depending on how much you get ripped off... not really sure how to tell if your sensor is going... it is attached to your exhaust just before the extractors where the engine pipes become one (post exctractors before cat).
i wouldn't be adding octane booster if your running fuel over a 95 octane rating, the fto will happily run on fuel from 95 and above.
as you always run aircon (and i so know why) you're getting pretty damn good fuel econ... there will be a difference in fuel econ from econ mode and full aircon mode... have you changed the way you operate your aircon? in econ mode the compressor only runs when its required to keep the car at x degree's... in full mode it runs constantly.
does this help?
just a bit of trivia from a friend who races motor bikes he says that the lower the octane rating you can run (Without pinging) the better it will give you more power.... i haven't dyno'd this to prove it and i'm not sure of the theory behind it but it may be worth testing.
here we pay between 8-10cents per litre for mobil 8000 and other fuels of similar quality what are you paying?
ruchi
Post by ruchi »
smorison wrote:here we pay between 8-10cents per litre for mobil 8000 and other fuels of similar quality what are you paying?
8O I think you either left out the word "more" (i.e. 8-10c more than standard petrol) or you've got a VERY special deal that I want in on! :D
smorison wrote:just a bit of trivia from a friend who races motor bikes he says that the lower the octane rating you can run (Without pinging) the better it will give you more power.... i haven't dyno'd this to prove it and i'm not sure of the theory behind it but it may be worth testing.
To provide a very simplified example:
Car A is designed to run on 95 RON fuel
Car B is designed to run on 100 RON fuel
If you put 95 RON fuel in both cars, Car A will perform normally while Car B will under perform and have detonation issues
If you put 100 RON fuel in both cars, Car A will over perform while Car B will perfrom normally
If you put 105 RON fuel in both cars, both Car A and Car B will both over perform, but as a percentage the RON rating of the fuel vs the RON requirements of the car are much higher for Car A and it will over perform more than what Car B will
Make sense? :D
For a real world example, BP Ultimate (98 RON) will make a Commodore or Falcon over-perform as they were desgined to run on 92-95 RON fuel. Whereas for us FTO owners it will only make our cars run at the normal level, as they were desinged to run on 100 RON. :?
MIVEC is My Friend :D
FTO338
Post by FTO338 »
Well i guess we can always re-programe the FTO ECU to run on 98ron instead of 100ron, so we'll be always run on optimum level in Oz.
GPXXX
Post by GPXXX »
FTO338 wrote:Well i guess we can always re-programe the FTO ECU to run on 98ron instead of 100ron, so we'll be always run on optimum level in Oz.
funny, i was always under the impression that the stock factory ECU on the FTO is non-reprogrammable? :roll:
wildfaye
Post by wildfaye »
smorison wrote: as you always run aircon (and i so know why) you're getting pretty damn good fuel econ... there will be a difference in fuel econ from econ mode and full aircon mode... have you changed the way you operate your aircon? in econ mode the compressor only runs when its required to keep the car at x degree's... in full mode it runs constantly.
I've been running the aircon in econ mode since the day 1 got the car.
Hmm, i guess i better check that O2 sensor out. Will the Mit Mut2 ecu dianogsis eqmt be able to find out if there's an error in the O2 sensor?
Petrol here is expensive! I always run on 98 petrol and i done think there are any >98 petrols ard here.
smorison
The Godfather
Post by smorison »
it may, not sure. if the 02 sensor is simply worn out it won't pick that up
wildfaye
Post by wildfaye »
Yups, will getr it checked as soon as i got time 2 go down to e garage and update u guys, get my aircon serviced as well, i think e thermostat is dying.
Btw, do you have a full list of MUT2 error codes?
FTO338
Post by FTO338 »
Ever heard of programmable piggy back before??? :roll:
