cat converters are aftermarket ones worth it over stock
- Benedict_XIII
was reading a few magazines and these catco and how good they are metal cat bla bla bla and was wondering if there worth the steel there forged ifrom anyone put one on and noticed a difference performance wise
I put a high flow cat on recently (2 weeks ago) and am happy to say that yes it makes a difference
I put a magnaflow on mine.
of course it makes a big difference but thats only if you upgrade the rest of the exhaust. Theres no point upgrading the cat while still keeping the rest of the restrictive factory exhaust
- aza013
- NSW Coordinator
some timesI8A4RE wrote: Theres no point upgrading the cat while still keeping the rest of the restrictive factory exhaust
so you still can get a result.
Re: cat converters are aftermarket ones worth it over stock
Benedict_XIII wrote: noticed a difference performance wise
You can notice 3kw difference? ........BSI get a +3kws
And what i said was there's no ppoint unless you remove the rest of the restrictive factory exhaust, the rear muffler is the most restrictive bar the cat
No, disagree. When I swapped out the cat, I still had the factory exhaust (apart fropm the extractors). I definitely noticed a difference even then. Even better when I swapped out the rest though. Having said that, my factory setup was already 2 and a half inches (I think that was an aero or version R option)
- aza013
- NSW Coordinator
I too did not say I could notice the 3kws, this was found on the dyno. standard cat test drop it out high flow in and retestI8A4RE wrote:Benedict_XIII wrote: noticed a difference performance wiseYou can notice 3kw difference? ........BSI get a +3kws![]()
And what i said was there's no ppoint unless you remove the rest of the restrictive factory exhaust, the rear muffler is the most restrictive bar the cat![]()
- nikhan
WEll...get a sports exhaust, hight flow cat, rpw extractors, CAI topped up with a e-manage will reap some gains on the car. 2.5 inch piping will do. If thats not enough, take out the spare wheel add in a carbon fibre boot and bonnet, use lightweight flywheel and lighter rims will make the car faster. Lolz...and if tat is still not enough, add in the happy gas
Lol, nicenikhan wrote:WEll...get a sports exhaust, hight flow cat, rpw extractors, CAI topped up with a e-manage will reap some gains on the car. 2.5 inch piping will do. If thats not enough, take out the spare wheel add in a carbon fibre boot and bonnet, use lightweight flywheel and lighter rims will make the car faster. Lolz...and if tat is still not enough, add in the happy gas
- vipfto
actually easy just remove cat put in vice and get bar and hammer and bash all the crap out, just do it ALL or you will have that rotten egg smell which is a dead give away that you have done it, just remember only for track usexSlurpee wrote:punching out a cat difficult? ... i already know the consequences for doing it though![]()
still willing to do it just to make my car abit quicker
Normal disclaimer applies
- rock_it
- Benedict_XIII
- RallyMad
Cops can mate. If you cruise around on thrusday nights or other nights you may have seen defect stations. They can stick a probe up your exhaust and test your emmisions at these stations. It will tell them if you have no cat. Then you wear a massive fine because it's a EPA regulation and not just a vehicle law.Benedict_XIII wrote:ok ok after reading and analysing the data ive come to a comculsion..................race cat.................................who has a spare cat converter lying around if its the cheapest and most power gains straight through all the way
can the cops pick up on it
My tip, just get a decent high flow cat. Go and talk to an exhaust shop.
- yano
Magna's came in a 3l and a 3.5l v6... I've got no idea if the 6a12 can be bored out though... I'm kinda curious myself...rock_it wrote:A little off topic, but not wanting to start a new one...
but can you bore out the 2.0L FTO engine ... To be the same size as the V6 in the Magna .. Is it 3.2 or something like that
