noise when air con is on
- bushido
what needs replacing if when i have my air con on and i stop at lights for a while, the take off and a sound like a stuffed up belt or pulley appears? Only happens when the air con button is pressed. Its ok just using the fan.
- zaskar98
- rock_it
- bushido
- vipfto
the air con and powersteer run off the same belt its fine if you dont use aircon as its just putting extra load on the pully, try to tighten belt via tensioner (underneath the motor) then replace belt as due anyway if its pully should not be too expensive to replace or you can just do away with aircon completely you wont lose heater or fans but will be hot in summer
- bushido
- zuihoujueding
- zuihoujueding
- bushido
What does this air con compressor cluth look like? last time i got it serviced, the dude marked out a pulley that needed to be replaced. I still havent done but will take some pics to shwo what i mean.
