noise when air con is on
bushido
Post by bushido »
what needs replacing if when i have my air con on and i stop at lights for a while, the take off and a sound like a stuffed up belt or pulley appears? Only happens when the air con button is pressed. Its ok just using the fan.
zaskar98
Post by zaskar98 »
Either the belt is loose and slipping when the a/c is engaged, or the bearings in the compressor itself are stuffed. If it's a squealing sound it's more likely to be the belt slipping, if it's a rougher sound then bearings/compressor itself is more likely.
hopefully it is just the belt ... It could be loose ... Or yeah slipping ... Otherwise, I think to replace the pulley is gonna cost a bit ... I had to do it on one of my other cars, as the pulley had actually been worn down ... It was not cheap ...
bushido
Post by bushido »
as long as i dont use air con will it be ok?
and will a major service address this? my belts need replacing anyway even though i just hit 60 k km :roll:
vipfto
Post by vipfto »
the air con and powersteer run off the same belt its fine if you dont use aircon as its just putting extra load on the pully, try to tighten belt via tensioner (underneath the motor) then replace belt as due anyway if its pully should not be too expensive to replace or you can just do away with aircon completely you wont lose heater or fans but will be hot in summer ;)
bushido
Post by bushido »
i dont even use air con .. just the recent rain been fogging the widnows up!
zaskar98
Post by zaskar98 »
I think bennoz has still got an a/c compressor for sale if you need one
Sounds like the air con compressor clutch is starting to go. Got a spare for sale, $175 if you want it. You're welcome to borrow it too see if it fixes the problem, you'll need to bleed then regas the system to put it in thou..
zuihoujueding
Post by zuihoujueding »
my gives a "tek tek tek tek" sound for like 30secs everytime i switch the mode to external. its annoying!
zuihoujueding wrote:my gives a "tek tek tek tek" sound for like 30secs everytime i switch the mode to external. its annoying!
If its only when you flick from recycled to fresh, then thats different. More than likely a leaf stuck in a vent or one of the little servo motors failing.
zuihoujueding
difinitely not a leaf or foriegn object stuck in it.
yeah, like you said it happens when switched from recycled to fresh. is there any solution? i heard its a common problem?
bushido
Post by bushido »
What does this air con compressor cluth look like? last time i got it serviced, the dude marked out a pulley that needed to be replaced. I still havent done but will take some pics to shwo what i mean.
