Trans Code 42,43,44
Sugar
Trans Code 42,43,44
Post by Sugar »
42 2rd gear ratio does not meet specification
43 3th gear ratio does not meet specification
44 4th gear ratio does not meet specification
were the codes i got.
TCGPX had the problem of 1 of them, however i couldnt find the outcome.
is it safe to asume the box is dead?
have you read the manual?? If you still need the info i may be able to look it up for this week end but no promises :D
I swear I've heard of this problem happing before, have you searched Sugar? And from memory, the actual problem codes (42,43,44) were completely different from what the problem was!
nicholas
Post by nicholas »
What is the problem you're experiencing?
In my old box the synchro from 2nd to 3rd was stuffed and always ground when changing between at high revs, so I would've expected to get an error code of 42 and/or 43... but are you having different problems?
Resident Asshole.
Storm
Post by Storm »
It usually means the input and the output signals from the sensors are not as expected. That is, you probably have a faulty sensor and I would guess at the input sensor.
