6A13TT Engine/ECU/Uncut Loom
- Hotwire
Hi all,
Recently I had some transmission problems after importing my Legnum VR4. As such, I recently aquired a 6A13TT engine package of Engine/Trans/Transfer case/Loom/ECU/ of which I used the transmission for my car.
I'm now left with the Engine, Full uncut loom, ECU's (Engine,Auto & TCL) and piping. I would like to sell the lot for $1,000 plus delivery, but would also consider parting it out, pending if I can get enough money back from the parts. I.e. if you wanted ECU, Turbo's, manifolds, Loom, ECU etc, make an offer and if I can get enough interest in the parts individually I'll let them go.
I have read that the turbo's and manifolds can be used to turbo the 6A12, or the whole 6A13 package can be bolted in. The loom was removed without cutting a single wire, and all connectors are there to be wired in. I can get access to full pinouts of the ECU also, should someone want to go aftermarket etc.
So please post up what you are after and I'll decide from there. Although my preference is to sell the lot in one hit, parting it out may be the way to go (pending interest).
Cheers
Lee
Cheers
Lee
where abouts are you?
- Hotwire
- BorepYano
no gearbox or drive train?
this may sound like a very very noob question, but can someone confirm is i'll be able to stick this + an awd gear box and diff, dirve train etc into an fto shell
- Hotwire
price drop
Now looking for $850 for the lot (plus shipping)
- Hotwire
Exact kms are unknown unfortunately, but I think ~90k. The parts retailer I bought it off does not import any engines over 100k so definately less than that. It's had the timing belt changed which mitsubishi recommend at 85k for the 6A13TT.
The trans i've used is in excellent condition, (can tell its be regularly serviced) as would the engine be.
- BorepYano
lots, and no you can't keep the gear boxcjam wrote:any ideas roughly how much it would be for freight to sydney? and very noob question.. the 6a13tt drops into the fto reasonably easy doesnt it but can the fto 95 tiptronic transmission be used?
- cjam
- Hotwire
why not, i was sure the box was interchangableBorepYano wrote:lots, and no you can't keep the gear boxcjam wrote:any ideas roughly how much it would be for freight to sydney? and very noob question.. the 6a13tt drops into the fto reasonably easy doesnt it but can the fto 95 tiptronic transmission be used?
