Danny's And Jeff's 6A13 turbo Conversions
dannyboyau
Post by dannyboyau »
Thanks very much Jeff
I realised i had you phone number after i made the post :oops:
Jeff
Post by Jeff »
Hi all,
Just an update on my car.
Still having problems with heat melting my gearbox selector cables. Had Paul at Crossley have a look and he insisted that he could heat sheild them for me. So after waiting for a new set of cables, he installed them, and heat shielded them. After 1/2 an hour on the dyno, guess what?. Yes they had melted. So back to drawing board.
Anyway for some good news.
With a better tune, and getting rid of the lean spots, my baby is now making
306kw atw.
Yep, over the magic 400hp figure.
When I get time I`ll post the dyno chart.
Jeff
Jeff
Post by Jeff »
As for above post from Danny.
He has organised for PWR to make an aluminimum radiator for us. I have organised a spare radiator for them to copy and measure, so hopefully in a couple of weeks it should be available.
Cost was roughly $800.
I`ll let you know how it is going.
Jeff
Jeff
Post by Jeff »
Here it is. Jeff
dannyboyau
looking good Jeff
Good to see that motor putting out some nice power figures.
Any chance of seeing a few more detailed photos under the bonnet, I am curious to see where they mounted the waste gate and get a closer look at the inlet and exhaust manifolds they made. See if there is any ideas there i can use. :wink:
Looks like it is running good, did you get it back for christmas ? and did they say when your radiator will be ready. I am hoping mine will arrive friday but might get held up by the holidays.
Jeff
Post by Jeff »
Hi Danny,
I`ll try to get some more photos up during xmas break.
As for my radiator, they said 10th jan. My car is up and running, and finally I can change gears easily. The only problem is now overheating. I think it is more than the radiator though.
The other day I drove it sedately for 2 kms parked for 1/2 hour then drove home only to have it boil. Interestingly the bottom rad hose was cool with the top one red hot. So I think my thermostat has sh*t itself, or my water pump.
If anyone has any ideas on how to discriminate between the two, without pulling the thing apart, I would be pleased to know.
Merry Xmas to all.
Jeff
Thermostat is easy enough to test if you pull it out. Just chuck it in a pan of boiling water & see if it opens. If not, its shot :wink:
Jeff
Post by Jeff »
Thanks Ben, but not easy to pull out.
You forget that I have a huge hairdryer blocking the way.
I was hoping to diagnose the problem without having to pull it out.
Jeff
fkndonut
Post by fkndonut »
Jeff, those chicks in your avatar are feral. :/
dannyboyau
you obviously don't know any feral women
BuCkEt
Post by BuCkEt »
dannyboyau wrote:you don't know what feral is if you think those girls are. Because if you knew any feral women you would know there not feral,
......dude, you could have sooo pwned him a lot better than that.
Something like....."Oh so you're *~delightful!~*?" would have done! :lol:
dannyboyau
is that better
dannyboyau
took some photos of the alluminium radiator before I installed it. Will take some more in the new year when i have given the engine bay a clean.
dannyboyau
jeffs avatar :D
personally i find it sort of hypnotic
makes you want to reach out and give them a little bit of support
Mmmmmmm, avatar...
Huh?
Oh, what were we talking about again? :oops:
Jeff
Post by Jeff »
Just an update.
2 days before the Qld cruise, a D#$K head backed into me in a carpark. Not much damage but managed to put a hole into my intercooler with his towbar.
Glad the weather has cooled down, no longer overheating. Waiting for PWR to fix the design fault with the new aluminimum radiator Danny and I have been working on. Now it has cooled, and when I get a new intercooler will have to go to willowbank and try for the new 1/4 mile record.
Jeff
RichardB
Post by RichardB »
Looks like you guys are beating me on the power stakes so Im going to convert it to single turbo over the next coming weeks. Anything I need to watchout for other then melting cables.
Just in the middle of fitting the Galant gearbox, not too many issues once I found the correct FTO driveshafts to fit, will be finishing the gearbox this weekend.
dannyboyau
going big single above the gearbox ?
ceranic coat turbo and manifolds
heatshields around turbo amd manifolds
vented bonnett to assist with cooling
bigger radiator with custom channelling of air flow
dannyboyau
Jeff have you heard anything from PWR about the radiator.
Jeff
Post by Jeff »
Just fitted the radiator last weekend.
Fitted great. They have fixed the rounded section on the bottom. Seems to be working well, although have not been to the track.
Also fitted my new PWR intercooler. I`m not sure whether it was loss of boost from a leak in my old intercooler, or the new PWR one, but it seems to have more grunt.
I`ll have to try to make it to Willowbank soon, for a 1/4 mile.
Thanks Danny.
Jeff
