Danny's And Jeff's 6A13 turbo Conversions
- dannyboyau
Just thought i would post a link to a couple of photos of the conversion so far for any one interested will update the photos every few days
http://photos.yahoo.com/dannyboyau
- dannyboyau
we are hoping about 2 more weeks
but probably closer to 3 weeks
the ceramic coating is going to take almost a week
but should be sending the parts to be ceramic coated on thursday or friday
will be doing most of the wiring while they are being done
will have some more pics tomorrow i forgot to bring the camera home with me today
nice !!
Nice work so far, It'll be good to see the finished result, how much was the motor and parts u needed ?? how much in laybour ?? did you need a new ecu ?? did u need ot modify the engine to fit ?? I thought the 6a13 was twin turbo
- dannyboyau
it looks like it will cost about 15000 all up for the conversion that included BOV, external waste gate, turbo garrett GT30, intercooler and plumbing, manifolds, engine, ceramic coating, wolf 3D version 4+, 4 puck ceramic clutch, walbro 255 lph fuel pump, two extra 550cc injectors, falcon 65 mm throttle body, 3 inch stainless dump pipe, stainless heat shields, silcone hoses, braided hoses, most of the labour i am doing myself. The engine bolted straight in, just decided to go for a big single turbo, I still have the twin turbos and manifolds from the engine. but when we went single turbo it created quite a few mods some small some a bit bigger. Some of the mods where done to make it all work more efficently, some of them are probably not absolutely necessary
- dannyboyau
yes the manifolds will bolt straight on to the 6A12 you just need to make a few minor changes to the piping on the fire wall and you will need to move the oil filter or if you get custom manifolds made they would fit very easily and there would be very little modification needed in the engine bay, rpw in Perth is in the process of making turbo manifolds at the moment. I went single turbo now instead of later. once this stage is finished will start getting the parts to do the internals
- dannyboyau
do you have a limited slip diff
I am aware there possibly will be torque steer and will be putting netto drag tyres on it so it will be hurting my pocket every few months for tyres but hey a mans gotta do what a mans gotta do, I just love the look of the fto but think it needs more power and i want to surprise a few skylines and rexs
by the way just updated the pics
every thing was taken off again to day and will be delivered tomorrow morning for ceramic coating
- MattG
Most front wheel drive front engined cars go through the front tyres quickly. This can be offset by buying a harder compund (harder weearing tyre) however this usually has the side-effect of not being so grippy.
(eg racing slicks are quite soft but very grippy).
Unless you were doing burnouts in your FTO I don't think adding a turbo will make much of a difference, although the weight of the whole system may make a very slight difference.
M@
M@
The Data Recovery Experts
- dannyboyau
hopefully there will be a little bit of differance when i add the turbo, ![Wink :wink:](./images/smilies/icon_wink.gif)
i expect to go through tyres a bit more often then now because i will be using much softer tyres,
the ones on there now are 10 months old and still good 50 % on them and have been good with the mivec engine, but i think i will need a bit better now
- dannyboyau
- dannyboyau
just added a couple more pics i took yesterday and will add some more this weekend should almost be finished then, the wiring is under way and almost put it all back together today
according to http://www2u.biglobe.any.jp/~fto/fto/inf ... une-e.html
is it lowered -35mm using ohlins suspension
does anyone know how i can contact Akihiko Nakaya himself?![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
- GPXXX
- dannyboyau
My FTO came with the suspension lowered 35 mm and i tried once to contact Akihiko Nakaya, but got no reply.
Mickey so happy to hear it fitted ok and cant wait to see the pics, I airbagged the bracket this morning and they said it will arrive your home on monday.
I had to modify the version R front bar slightly to get it to fit but you would be hard pressed to notice the modification.
All the fuel lines and fittings arived today so we will put them on tomorrow we had temporary lines to get it going and she is running and purrs like a kitten. now just to dyno it.
will post new pics tomorrow night.
Thanks again for your help mickey
