Wrecking whole car
pokai41
Re: Wrecking whole car
I am really interested about the air-con compressor.
how much would postage be to brisbane??
Could you please provide the photo as your convenience. thanks so much~
Done, no problemAstron_Boy wrote:Is collection payment at the Xmas party cool Bennoz, or would you rather before then?
Vents - no probs will pull out this arvohhakan wrote:aircon vents (all of them)
boot interia (the carpet and wood thingy)
and the aircon unit
and other minor stuff that i cant think of yet
Boot int - No probs, its all there. Wood board is a little warped, but could be reshaped
A/C - As in the climate control unit in the dash?
Yes they will fit. I actually have a second manual set, but the rubbers are almost shot in them. You could grab inserts from Auto One & press them in if you wanted to reco them.FTO-BOY wrote:So I take it as the manual engine mounts don't fit on a tip?
Apologies mate, but rims are now gone.bob_oz wrote:i'm after a single 16" stock rim or a pair of rims,
did it have the 5-spoke type silver stockies on it?
Can do, will take it out this arvo & take a pic.pokai41 wrote:I am really interested about the air-con compressor.
Hang on.Bennoz wrote:Yes they will fit. I actually have a second manual set, but the rubbers are almost shot in them. You could grab inserts from Auto One & press them in if you wanted to reco them.FTO-BOY wrote:So I take it as the manual engine mounts don't fit on a tip?
I swear that I read the manuals couldn't be used with the autos due to there design and size...
Will read over the thread now, but I was next to postivie, again otherwise you wouldn't have that cross member, I would have collected on the day then and there.
Do need as our engine is sitting on the cross member, no rubber mounts at all.
Edit: viewtopic.php?f=23&t=15195
Have I read it wrong?
- Eltnot
Folding mirror switch received, cheers.
Astron_Boy wrote:Hang on.Bennoz wrote:Yes they will fit. I actually have a second manual set, but the rubbers are almost shot in them. You could grab inserts from Auto One & press them in if you wanted to reco them.FTO-BOY wrote:So I take it as the manual engine mounts don't fit on a tip?
Its the same cross member, same mounting brackets on the box, same mounting points, same metal frames on all mount types.
The only difference is in the bushing itself, tip have an open bush, manuals are solid rubber. Why wouldn't you want solid mounts if you drive hard? Less torque lost through engine twist.
Only difference is a bit more cabin vibration.
Nah, I well realise all that, but from observation of what I saw, the tips had a smaller size rear mount rubber, and was slightly angled in one direction to which the manuals did not?Bennoz wrote:![]()
If they are identical, then I'll def take it off you as I need it, one big thing stopping the car from being driven.
Meanwhile, what's wrong with the forums sync lately? Latest replies are all showing up whacked in the index.
EDIT: Gonna strap my size 15s on for this one (I say 15s as I have size 12s already)
If I were to bring the FTO, could we perhaps drop and install on the Sunday after Xmas party?
Can help refill your fridge...
Macca
Do you have any pictures of the front seats Ben?
- Taiwo
Do u have radiator n condensor n all the plastic bits. If so how much are u willing to let them go for.
- zuihoujueding
Still.have driver side front wheel arch liner and under tray?
- JOA81
Wrecking whole car
Do you happen to have the panel that surrounds the instrument cluster with a fog light switch in it like this
Actually I do. How does $20 + postage sound?
- JOA81
Wrecking whole car
Ok so that's for the panel and the fog light switch because I'm after the fog light switch as one of my ftos doesn't have it and I just put fog lights on it
- zuihoujueding
- Star_Lancer
I'd be interested in the passenger side door speaker cover! How much?
Sorry, the fog light switch is gone.
Got both the arch liner & speaker cover. Make me an offer
- JOA81
- Rosiebella
i do need a left tail light.. so if its not gone let me know
- Taiwo
do u still have the kick plates and the wood grain tip box
Kick plates no, wood grain tip surround yes
- Taiwo
how does $30 sound for the wood grain surround or a 6pack of your favourite beer
