Biggest & best breaks for a FTO
d_dan
Post by d_dan »
with my turbo conversion I want bigger better breaks,
Whats my options.
I dont mind fabricating brackets
J
Post by J »
i think dwayne is selling porche brakes which apparently fit the fto
Well thats my 2cents :D
jay6 wrote:i think dwayne is selling porche brakes which apparently fit the fto
no sam is ;) and no, modification is needed
apart from needing 18" rims to fit them into.
sorry i meant mods ARE needed to fit them.....aswell as 18 inch's ;)
Jamie
Post by Jamie »
Try the DBA website. They have a few to choose from. I would suggest something like the 4000 series rotors with some decent pads and fluid.
Here is a pic
<a href="http://s459.photobucket.com/albums/qq31 ... rotors.jpg" target="_blank"><img src="http://i459.photobucket.com/albums/qq31 ... rotors.jpg" border="0" alt="DBA 4000 series front rotor"></a>
FtoSam
Post by FtoSam »
if you've got the dosh, i was selling mine... not too sure anymore...
they dont come any bigger than 6 piston porsche brembo's.
They require a 353mm rotor to clamp on to.
they are massive..
currently asking $1700. Worth over $8k and are new...
d_dan
Post by d_dan »
really wouldnt like to go bigger than 17's
Iv got big enough pockets with this one as they will be one of the things keeping me away rom the barriers at trackdays and at nurinburg this summer
vipfto
Post by vipfto »
You can get a complete upgrade for 17inch wheels including rotors/callipers etc via RPW or you can get from UK somewher but cant remember site cost should be around $1500+ or maybe you could go for evo or vr4 brake conversion.....
vipfto wrote:You can get a complete upgrade for 17inch wheels including rotors/callipers etc via RPW or you can get from UK somewher but cant remember site cost should be around $1500+ or maybe you could go for evo or vr4 brake conversion.....
Early Evo (VR4) are the same twin spot brakes... Well as a GPX, so no real gain there ..
You could look at the 3000GT brakes ... I have seen them put on an Evo III, and the only problem for clearance was the wheels... Other then that it all fitted... So as the Evo III has the same brakes, I would assume that it should also fit the FTO ..
SG
Post by SG »
My plan was to get the dba 5000 series rotors from an evo4 and use the same calipers from my fto.. all you need is a new bracket the hold the calipers on because the bolts line up differently... evo 4 are 294 mm.. evo 3/fto are 276mm and are no different except they're 4 stud(?)
FtoSam
Post by FtoSam »
mine will fit under forged 17s...
FTEvolution
Post by FTEvolution »
Evo V+ Brembos and discs, no point doing anything less than that or bothering with a different make conversion as they are a simple bolt on with only minor fabrication of brackets needed...
Clicky for $1200 (NZD) set of Evo VI Brembos in new Zealand
Check it out! Anything else is overkill and definitely a waste of money and effort.
Smooth and sleepy
Bit of an oldish thread, but I'll reply anyway as it is input.
Tenji I noted has GTO brakes.
Unfortunately doesn't know of how they are fitted, but we know they fit!
Can be sourced as well as FTO rotors...
GTO brakes will fit, you just need a 324mm rotor with correct offset & the mounting bracket. Guy in the UK is doing them.
nicholas
Post by nicholas »
What's the best option if I wanna keep 16s?
By best, I don't mean JUST performance. I mean overall:
- decent performance increase on stock
- fit with 16" rims
- value for money (NOT cheapest, but NOT most expensive either)
- minimum or no modification needed
Any ideas?
Resident Asshole.
FTEvolution
IMO the easiest would be Legnum/VR4 brakes. Just IMO though. Good bang for buck too
Smooth and sleepy
vipfto
Post by vipfto »
nicholas wrote:What's the best option if I wanna keep 16s?
- fit with 16" rims
Any ideas?
I suggest upgraded rotors, good pads and BLEED THE BRAKES that is one thing not many people do you would be suprised at how much better they work with new fluid
- fit with 16" rims
Any ideas?
AHMEN to that.
alekazam
Re: Biggest & best breaks for a FTO
Post by alekazam »
I found this how to for an FTO / GTO brake conversion http://www.scribd.com/doc/30471824/MITS ... of-Jinglis
