Biggest & best breaks for a FTO
- d_dan
with my turbo conversion I want bigger better breaks,
Whats my options.
I dont mind fabricating brackets
Whats my options.
no sam isjay6 wrote:i think dwayne is selling porche brakes which apparently fit the fto
Well thats my 2cents
- aza013
- NSW Coordinator
sorry i meant mods ARE needed to fit them.....aswell as 18 inch's ![Wink ;)](./images/smilies/icon_wink.gif)
- Jamie
Try the DBA website. They have a few to choose from. I would suggest something like the 4000 series rotors with some decent pads and fluid.
Here is a pic
<a href="http://s459.photobucket.com/albums/qq31 ... rotors.jpg" target="_blank"><img src="http://i459.photobucket.com/albums/qq31 ... rotors.jpg" border="0" alt="DBA 4000 series front rotor"></a>
Here is a pic
- FtoSam
- vipfto
- rock_it
Early Evo (VR4) are the same twin spot brakes... Well as a GPX, so no real gain there ..vipfto wrote:You can get a complete upgrade for 17inch wheels including rotors/callipers etc via RPW or you can get from UK somewher but cant remember site cost should be around $1500+ or maybe you could go for evo or vr4 brake conversion.....
You could look at the 3000GT brakes ... I have seen them put on an Evo III, and the only problem for clearance was the wheels... Other then that it all fitted... So as the Evo III has the same brakes, I would assume that it should also fit the FTO ..
- SG
- FtoSam
- FTEvolution
Evo V+ Brembos and discs, no point doing anything less than that or bothering with a different make conversion as they are a simple bolt on with only minor fabrication of brackets needed...rock_it wrote:Early Evo (VR4) are the same twin spot brakes... Well as a GPX, so no real gain there ..vipfto wrote:You can get a complete upgrade for 17inch wheels including rotors/callipers etc via RPW or you can get from UK somewher but cant remember site cost should be around $1500+ or maybe you could go for evo or vr4 brake conversion.....
Clicky for $1200 (NZD) set of Evo VI Brembos in new Zealand
Check it out! Anything else is overkill and definitely a waste of money and effort.
Smooth and sleepy
Smooth and sleepy
- nicholas
- FTEvolution
- vipfto
I suggest upgraded rotors, good pads and BLEED THE BRAKES that is one thing not many people do you would be suprised at how much better they work with new fluidnicholas wrote:What's the best option if I wanna keep 16s?
By best, I don't mean JUST performance. I mean overall:
- decent performance increase on stock
- fit with 16" rims
- value for money (NOT cheapest, but NOT most expensive either)
- minimum or no modification needed
Any ideas?
AHMEN to that.vipfto wrote:BLEED THE BRAKES that is one thing not many people do you would be suprised at how much better they work with new fluidnicholas wrote:What's the best option if I wanna keep 16s?
- fit with 16" rims
Any ideas?
- alekazam
Re: Biggest & best breaks for a FTO
I found this how to for an FTO / GTO brake conversion http://www.scribd.com/doc/30471824/MITS ... of-Jinglis
