My starter is screwed. I had the brushes replaced about a year ago, and now it's dead again. So I rung around the wreckers and it seems that $100 is the going price.
Now, the question is... can I replace this part myself? I mean, it's right at the bottom of the car. So all I need to do it jack it up and do a straight swap? Remove various bolts and then replace in reverse order?
Picked up a second hand starter this afternoon and fitted it. Worked the first time. Had a bastard of a time getting out, but getting it back in was quick and easy. Thanks for the advice. Probably saved a bit on labour.
So now I have a spare starter motor. I should probably have it refurbed and sell it on.
Blasphemy wrote:Picked up a second hand starter this afternoon and fitted it. Worked the first time. Had a bastard of a time getting out, but getting it back in was quick and easy. Thanks for the advice. Probably saved a bit on labour.
I hope you also refurb'd the second hand one, they may seem fine, but those brushes can be pretty worn.
I replaced mine a month or so ago, the second hand one was put onto the test bench and it worked, then $30 later and another set of brushes had the thing fair humming. Twisted the bench top vice that wasn't quite bolted down properly.
Nice and cheap for a bit of peace of mind I think...
