What stud pattern are ftos ?
- wogboy
what the topic says having problems got wheels today came off a car thats 5x114 i thought ftos were 5x114 is it at all possible ftos are somthing else ?
thanks
thanks
- FTO338
FTO is 5 x 114.3 what sort of problem you got with the new set of wheels? Whats the offset?
- Hobbsie
- Hobbsie
- FTO338
Chris is right Sky.line have the same PCD pattern and I've swapped the wheels between sky and fto before.khunjeng wrote:they are the same pattern
Is the wheel multi stud? What size is the wheels, like 17x8, 18x8....etc
- FTO338
Is it dead set on 5x 114 and not 5 x 114.3? Hmmm that could be your issue here.
I just hope you didn't try to put it on with the wrong PCD pattern, as you said, it is a multi fit.
