GR intake adaptor
GR intake adaptor
I've just had an idea (I know.."Calm down" your thinking lol "I can see smoke comin' outta your ears")
For those of you who have a GR & want to put a pod filter / proper intake pipe on, you need a little adaptor made up to bolt to the map (air flow) sensor to put the filter on.
If there are enough of you (put hands up please) that want one, what say I shoot down to the workshop & make up a dozen or so... do a little group buy?
Whaddya think?
This is what I mean:
jonowong
Post by jonowong »
can u make a 3" straight pipe to come out of an air filter to bolt on for the gpx?
jonowong wrote:can u make a 3" straight pipe to come out of an air filter to bolt on for the gpx?
If you (or someone) wishes to donate a GPX intake pipe Im sure I could wip one up :wink:
BorepYano
Post by BorepYano »
JOeJOe
Post by JOeJOe »
I have my old intake in the boot that you could use.
Off topic, the maf sensors, how much do they go for??
robsta
Post by robsta »
I can't see the picture because of the webblocker at work but I should be interested.
can you email the pic to me? i'll pm you my work email.
yeah id be interested depending on how much cause i brought 1 the other day but its for a massive pod and have decided against that. so yeah how much
Maybe 10-15 bucks... its only a 3" cut of pipe welded to a flat plate :?
yip ill buy 1 for $10 bucks now pm me the account to put the money into and also can you give me the part number for k & N pod
thanks mate
khunjeng
Post by khunjeng »
is that your engine ben?? had to believe u still have the stock intake pipe??
khunjeng wrote:is that your engine ben?? had to believe u still have the stock intake pipe??
Thats a very old pic mate :wink: In fact its maybe 20 mins after I bought the thing...
dimi
Post by dimi »
hey mate i will def take one. put me down
dimi
Post by dimi »
GOT A QUESTION
Just wondering how much better the car breathes with this mod done(pod filter),
How much gain would you get on a GR with this type of pod set up as well as rpw extrators and a straight through 2.5 inch exhaust, noticable, or not???
Thoughts opinions
Btw, i realise the pod will give approx 1-2 kw and the exhaust maybe 5 - 10kw, just want to know feeling wise
Cheers
Swapping out the stock piping will give you approx 4kws (dyno tested at UAS) the filter will add another 2-3. Proper header to tip exhuast will add anything from around 6-10 depending on how much $$ you sink into things like hi-flow cats / resonators & mufflers.
Stock my car used to produce around 88kws, its now pulling around the 120 mark.
Anyone else for the adpator? I might make up say 6....
robsta
Post by robsta »
yeh im in put me down for one
dimi
Post by dimi »
Bennoz wrote:Swapping out the stock piping will give you approx 4kws (dyno tested at UAS) the filter will add another 2-3. Proper header to tip exhuast will add anything from around 6-10 depending on how much $$ you sink into things like hi-flow cats / resonators & mufflers.
Wow thats a pretty big gain, what else did you do to get it up around 120kw.
Also the stock piping for 4kws and the filter for 2-3 any good performance shop should be able to do this hey.
Ther
Post by Ther »
i would be interested for a 3" pipe for the GPX if you are going to do that as well
khunjeng
Post by khunjeng »
dimi wrote:GOT A QUESTION
Thoughts opinions
Cheers
the pod itself probably wont do jack sh*t...its the intake pipe that will help you.
dimi
Post by dimi »
any progress??
sublime19
Sooty!
Post by sublime19 »
mm i think i alrdy have an adaptor? since i have a HKS does that have an adaptor on it alrdy? (u've seen my engine bay i dunno if u remember or not though) :?
