Car problems :(
kem
Car problems :(
Post by kem »
My car experienced problems a few months ago where it would just conk out when stationary or in reverse and wouldn't start unless i reved it on 1000 rpm for a minute or so i took it to a mechanic and they said the battery needed charging and then charged me $100 and didn't believe me when i said thats not the issue. So about a week when it just wouldn't start at all, i took it to another mechanix who tried to figure out what the problem was for 2 and a half weeks and after a lot of testing and failing; determined that the problem was the ecu and apparently this is a none issue for ftos so i had it replaced everything was ok for about a month but it still occasionally doesn't start first go. Just wondering if anyone out there would actually know what the problem is? Its so frustrating! i don't want my car to die again and i don't want to be messed around by a mechanic again... :cry:
fto617
Post by fto617 »
hows your spark plugs?
starter motor?
past ride : FTO gpx with lots of bling bling
Current ride: EVO 8 with the MOST CARBON IN AUSTRALIA....206KW AT ALL WHEELS
Check your error codes
http://www.ftowa.com/html/workshop/workshopart07.html
Alternatively take it to a Mitsubishi service centre & get them to plug it into the Matrix :wink:
ISC.
