High flow cat
- spetz
High flow cat
Gonna go buy a high flow cat for the car
At the moment just running a stock Magna/Verada cat
Just wondering, any benefits in spending close to $400 for a stainless mesh cat in an NA motor or should I save money and go a normal ceramic one for much cheaper?
- FTO338
I agree with dynamite here, there was a test a while ago on one of the maganzine and what they found was, N/A car lose power with straight flow cat then those with a bit of restriction.
I can recommend www.bosimporting.com.au for Catco cats for pretty good prices. He sells both the normal 'highflow' as well as the metal matrix ones so make sure you're getting the correct one. Also need flanges welded on which wouldn't cost more than $50 at your exhaust shop.
- FTO338
Yes i would recommend them too, i got like 10 highflow cats off them, one for my FTO, great products. They ship them pretty fast too. No hassle what so everkid_dynamite wrote:I can recommend www.bosimporting.com.au for Catco cats for pretty good prices. He sells both the normal 'highflow' as well as the metal matrix ones so make sure you're getting the correct one. Also need flanges welded on which wouldn't cost more than $50 at your exhaust shop.
- Nacho
- FTO338
- khunjeng
just get a good one for a few hundred...not the top of the range..u should be fine.Nacho wrote:Did they say why?FTO338 wrote:I agree with dynamite here, there was a test a while ago on one of the maganzine and what they found was, N/A car lose power with straight flow cat then those with a bit of restriction.
Hmmm
I paid almost $550 for a stainless top of the line cat. When I picked it off the shelf & looked through it, there was almost no restriction & you know what kind of power I pull out of a non mivec. I'd have to day, if you've got the coin go for it.... it made a HUGE difference to my performance (coupled with complete exhaust upgrade.)
I was under the impression that the majority of back pressure is created by the general size of the exhaust. Ie not going bigger than 2.5 inch suits the FTO well. Also very much dependent on your compression ratio - for instance the best size exhaust fitted to my mini was 3.25 inch coupled with 12.5:1 compression.
- khunjeng
yeah cos the cat does nothing but convert the bad stuff into bettertuff..its not there for flow thats for sure...many ppl remove them all together..
I looked at the stock CAT when it came off...and compareed to the new hi-flo..the difference is amazing...same goes with the muffler.
I just checked my FTO one...its a 500 cfm rated one for a 2.5" setup...I also have a hi-flo muffler..i.e. no direct baffels...I dynoed those together when it was on and I got about 7rwkw gain ..I paid about 400 fitted for the cat alone.
I think I paid about 650 fitted for my new ones on my soap box.
so there u go...
so there u go...
- spetz
I emailed that place and I can have either
2.5" hi flow ceramic of $160
2.5" metal cat for $240
So the difference is only $80 which means nothing to me and at the moment I want what will give me the best gain.
So, more flow, or more backpressure?
Also, I think the cat changes the exhaust sound and I think a metal one will make it sound raspy
- bigpitty1
- payaya
Size of exhaust depends on size of motor. No way the Mini runs such a big exhaust unless its forced fed.Bennoz wrote:Hmmm
- Supplanter
If memory serves me correctly it is a $60k supercharged Minipayaya wrote:Size of exhaust depends on size of motor. No way the Mini runs such a big exhaust unless its forced fed.Bennoz wrote:Hmmm
