Tappets/valve train/top end - here we go again....
Right. Meticulously went through and re-set the tappets as per the engine manual instructions. Double checked all the gaps before putting it all back together again. Start the car - and they sound worse than they did before!!!
So frustrating, cannot think why this would be.
Will be doing an oil flush and change shortly, so will see if that helps, but failing that, I have no idea.
If the gaps are too small or big, are they going to sound much the same? Also, how difficult should it be to get the feeler gauge between the cam lobe and the roller? They are fairly tight, but it does go in without too much effort and you can move them around.
Any feedback much appreciated.
- khunjeng
use a good oil filter, not a Ryco piece of crap - less pressure drop will help the tappet noise seen a few tests on Coopers but the OEM versions of all the Jap cars have seen good results, buy a Coopers or Mitsi OEM was like $9 a week ago. 0W40 M1 would be an ok choice. Failing that use Motul 300V or Redline if u have the cash.. I use a 5W30..have next to no tappet noise..only at idel you might hear them a bit...
My idle pully is noisy...needs to be replaced...actually makes u think its the tappets...buts its the pully...check them also.
- Storm
We're having the same discussion on and off on the UK forum as well. So far we have
1. Hydraulic lifters - apparently there are about three per camshaft for some reason I still dont understand
2. Header gasket leak - gives you a ticking type noise.
3. My alternator was making a noise and some WD40 quietened it as did a belt change
4. Injectors can make more noise than you would expect.
5. A rattle snake has hidden in your engine bay (No- that one wasn't really discussed
HTH
Arashi
HTH
Arashi
- khunjeng
the oil filter has a big effect on the tappet noise..I have a test somewhere but can't find it. Basically this guy in the us has a car with a similar issue as the FTO and he tested numerous filters for pressure, flow, effiency and "noise" of the tappets. The cooper and OEM ones worked well. Also the M1 filter but thats hard to get here.mrx wrote:Well, I think I can rule out number 5![]()
It is also not a head gasket leak, and not hydraulic lifters (MIVEC).
Warming to the oil pressure possibility, but unsure of that too.
Don't really feel like adjusting them again, but will do it if I have too.
Also Mitsi use a new Denso MZ690116 in their EVOs..you can get the "short" equiv. for the FTO...really good construction. I bought a new OEM recently...and it looks the goods.
the Ryco worked really bad in all tests which has been repeated a number of times in a number of forums I had read.
- Storm
I may have had a language failure across the world here. I meant the exhaust manifold gasket, not the head gasket. I was trying to be fancy as I thought you guys called them "headers"mrx wrote:Well, I think I can rule out number 5![]()
There are also, much to my surprise hydraulic lifters even in the MIVEC engine, see here at the bottom of the page.
Arashi
Ah - in my tired state I just read that as 'head gasket' but upon re-reading it in the morning I can see what you actually typedStorm wrote: I may have had a language failure across the world here. I meant the exhaust manifold gasket, not the head gasket. I was trying to be fancy as I thought you guys called them "headers"![]()
Arashi
I have noticed those little hydraulic thingies in there (I think you will find this is what they are actually called
Combine with oil change, new OEM filter and see what the result is. May even put an injector cleaner into the fuel to test that theory aswell.
- khunjeng
OEM. Mitis only stock 2 types, fat and thin - mz690070 its not too bad as few ppl have pulled it apart and reckon its ok from their EVO..thats uses the fat version. Else go look for a Coopers equiv. which should have a similar number as the ryco (Z411 I think but do a search) although I never have tried. It might not fix your problem, but its a good start to ensure u have decent oil pressure and you filter flow/filtering is good.mxysxy wrote:so, where do we get these fancy filters from?
product code?
If u have oil pressure guage see what happens. I have no def. answer but some filters can get stuck in bypass and hence drop you pressure...this is common when using a filter thats not spe'd right. THats why i say use a OEM one...just to keep it simple.
Im investigating for you Shaun. Am seeing my mechanic this arvo as he's done plenty of these.
I fail to see how a change of oil or oil filter is going to fix a tappet noise problem.... It will only disguise it at best. Something is making a ticking noise because there is a problem - we need to identify what that part is.
Think of the scenario:
The car pulled 108kw on the dyno - I dont think there is a oil pressure problem
The tappets sounded better before adjustment - meaning there may have a issue with the technique used to adjust them
There are a number of other things in a Mivec head that can go tap, tap, tap. Such as worn rocker assembly bushes, the hydraulic tappet stubs (as mentioned above,) missing tappet collets, a possible exhaust leak... the list is endless - but as they were better before adjustment, I am leaning to incorrect technique used to adjust them.
Yeah, i mean you could be right of course! It could just be me
But I will investigate these other things aswell. It is at idle where it is "rattling", and there is some obvious taping above that point.
Ben - if you could get some tips or feedback on anything in particular which you can do wrong, then let me know of course.
but reading through the forums on the UK, seems there may be some other issues floating around in our cars too (but that may or may not apply to me).
Will probably get a chance on Saturday to have another look, so if you could let me know anything by then it would be much appreciated.
How about something like the cam springs aswell? If there was one or more of these that weren't "springing" then surely this would be manifesting itself in a similar way? I just wacked the rocker cover off the engine in the garage, and a couple of them were really hard to move. (And no, they weren't the ones that the valve was open either.
I will also check the cam followers (rollers) to make sure they are all ok. Will re-check all the tappet gaps while I am at it.
Has anyone used one of those top-end treatment / flush before? Would it be recommended? This is an engine that was sitting around in a half cut for a while so just wondering if something like that might be worth looking at.
- khunjeng
tappet or lifter noise is assosiated with the oil passage being blocked with crap or not getting enough oil in cos its too thick.. i.e. cold start. At op temp a thicker oil will help rasie oil pressure a lot while the right filter can also help raise it a few psi if its designed correctly. But the main benifit is moving forward and helping the oil stay clean so the lifters dont get clogged again, this helps if u have a good filter - if u think they are all the same u have been mislead.Bennoz wrote:Im investigating for you Shaun. Am seeing my mechanic this arvo as he's done plenty of these.
however if your adjustment is way off then its probably not going to do anything. You need to start with a good base.
- payaya
FTO is 24 valve, 4 cams, so 6 lifters per camshaft. 1 lifter per valve. Injectors do tap but not enough for you to notice it without having your head next to them.Storm wrote:We're having the same discussion on and off on the UK forum as well. So far we have
5. A rattle snake has hidden in your engine bay (No- that one wasn't really discussed)
HTH
Arashi
Why not change the lifters??? Could be worn out.
