Brake Upgrade - Wilwood Calipers & EVO 4 Discs
Hi guys just wanted to let you know I just upgraded my brakes using 4pot wilwood calipers...
http://www.wilwood.com/Products/001-Cal ... /index.asp
Got the 120-6816 product but others may fit.
and EVO4 Discs.
It wasnt too difficult just needed a custom mounting bracket which I got a machine shop to make out of 3/8" steel for $40 for the pair. Another $40 in some automotive grade bolts, nuts and washers and thats it. Will take some pics later but they feel a heeeelll of a lot better than my stock 1pot GX calipers. I haven't even bled the brakes properly or bedded in the pads and already the difference is huge.
Wilwood calipers sell for about $330AU a pair on the net. I got some used but good discs from a friend but DBA also do the EVO 4 GSR discs ino the 4000 series for about $400AU a pair brand new. Available here but might be cheaper elsewhere? http://www.racebrakessydney.com.au
The discs are only about 300mm (about 20mm or .75" wider than GPX) but with the upgraded calipers are more than adequate for even my turbo car. No sense over killing in size cause size is weight also and thats unsprung weight.
They will fit on a 17" wheel quite comfortably and probably even a 16". I think that all in all the whole thing with pads and maybe even SS hose should come to about 1,000 AU with brand new parts.
If anyone is interested I can give you the general shape of the bracket to print out but I dont have the hole locations since I drilled them after.
When I'm in the mood I might also put up a how to on the whole thing.
Anyway I highly reccomend this upgrade to anyone. a lot cheaper ultimately than most big brake kits, loog good and these calipers are a lot lighter than even my 1pot brakes.
and EVO4 Discs.
- Hobbsie
- idawina
- spetz
- spetz
Didnt have to change my master cylinder. I think that would be necessary probably if you were going 6pot?
Yeah 330 would be good especially to look at but to be honest a disc that size would probably be overkill on a car that will never really see more than 230hp on a N/A or 275 on a t/c not to mention possibly rub even on some 17z. Thats 10mm bigger than comes on the EVO8. I think you would be better off sticking with 320 since it would be easier to get also.
Remember also with the current calipers we have since the pistons are only on one side it utilizes a kind of push and squeeze technique. In other words only one side is actually pushing the pad to the disc. The other side is getting squeezed by the effort but not directly. Therefore the 4pot having direct contat with both sides is a lot more effective at ultimately stopping the car.
When it comes down to it the biggest difference in stopping a car will almost always equate to piston surface area. Ultimately I dont think the effort is worth it if you're just upgrading discs but anyone is welcome to try and prove me wrong
- SG
braided steel brake lines gave me the biggest benifit that i could tell when i upgraded my brakes... but i also got mild slotted (same size) rotors and red stuff pads fitted to the front at the same time. But for feel the braided lines i reckon produced the biggest g's because you could push lightly down on the pedal all the way until the wheels locked up and you could get a good feel for the limit at where they'd lock up and keep it a big back from that spot... but thats low speed braking anyway... i'll be seeing how high speed braking goes this thursday when i go to barbagello raceways track night.
should be brake fade gallore
agreespetz wrote:The calipers might be better for feel etc but with them you'd need to change master cylinders etc
Where as I believe that with just larger rotors it will reduce brake fade
If you are changing calipers etc then may as well put some 330mm rotors
- FTO338
Dannyboyau still holding that title at the moment. But don't give upHobbsie wrote:cheap, looks good, and performs well.. awesome work
looks like your fto is shaping up to be one of the tuffest on the forums
BTW redline have you change your master brake cylinder yet?
Yes Dannyboy FTO is certainly a lot faster than mine however he doesnt have the 6a12 engine in so technically is it still an FTOFTO338 wrote:Dannyboyau still holding that title at the moment. But don't give upHobbsie wrote:cheap, looks good, and performs well.. awesome work
looks like your fto is shaping up to be one of the tuffest on the forumsBecause at the Poms site, they have fair few turbo and supercharged FTO. Someone got to show them ehehehe
As I mentioned earlier, I dont see a need to change my master cylinder as I have the brakes in and they're working great. Maybe if I went bigger?
Of course anyone doing the upgrade can put on any size discs they want with the right bracket, but obviously the bigger you go, the more it costs and heavier it is. So I went with a size that I thought was adequate, and it seems to be doing its job so far. Who knows I might upgrade later.
- SG
who was that member on here who sold their FTO that has quite a lot of mods on it? Full brakes/suspension/engine mount upgrades etc? and then someone nearby bought it and showed up on the forum. His was a pretty good FTO all-round... almost the same as mine except for wheels and rollbars
FTO only weighs 1200 kilos anyway, you shouldnt need to go too big compared to larger cars.. even evos weigh quite a bit more, and you end up with the same braking distance
you could probly out-brake a slightly older evo (5+) redlineGX just due to the weight difference
- BorepYano
its better this way then the opposite trust me.
i bought my 94GR for $12.5k, thought it was a good deal, had a budget of 15K, and now i keep seeing much much nicers ones for sale here within that budget >.<
and if i knew what i should do to my FTO, especially how much they are going to cost (an arm and a leg), then i wouldn't have pissed the rest of my car budget away >.<
better to know upfront then to find out one day when u accidentally stumble across this site while trying to look for offset details.
The to do list turns into an addiction. That's the problem. Especially with a site like this where you just keep seeing better n better FTO's. Everyone revvs one another up. No pun intended.Liquidity wrote:f*** me. the "to do list" is adding up already and i dont even have a damn fto yet.
I'll just confess I'm a junkie and be done with it. I got a lotta catching up to do...
- spetz
Since on the subject...
What about using 3000GT calipers?
Or even some other brand calipers like Holden, Nissan, Toyota?
Thinking that if going to change calipers may as well go well over 294mm rotors
And on that subject also, what is the largest rotor that could be fitted under 16" wheels? I realise caliper size is a key issue, but as a guideline
