Talking to RPW I was told that to make the 2.5L MIVEC needed 3 engines, 6A12 MIVEC, 6A13 SOHC and 6A13 DOHC plus a host of custom parts.
What I am thinking...
Why not ust use the 6A12 block to begin with?
A brand new 6A13 crankshaft from Mitsubishi is $800
This means the engine has been stroke but bore is still the same. But the bore is over 78mm as is and the 6A13 only has less than 3mm bigger bore, so the stock 6A12 MIVEC pistons can be kept just to keep cost down. Anyway, if someone wants to go bigger/custom forged pistons to actually make this a 2.5-2.6L they can, just by boring the 6A12 which should be safe if the same block already comes with a larger bore. At the same time, maybe the 4G92 MIVEC pistons fit? Same bore. Only problem I see is the valve seats on the dome may cause issues. Honda B series pistons might fit too.
Now we are left pretty much with just the conrod length. I doubt the MIVEC ones can be used, even though I realise rods can be somewhat resized I do not think over 10mm to compensate for the stroke. So maybe custom rods might need to be made. I got quoted $1600 for custom steel rods with ARP bolts included
I bet everyone is thinking now, but the 2.5L block is physically taller than the 2? Fair enough, but if anyone has also seen a RB26 stroker kit to 3L they would see that the kit comes with a sort of plate that goes on between the block and head. A CNC machined piece basically made out of alloy and o-ringed/sleeved block so there are no gaps.
Hopefully the cam belt tensioner leaves enough gap to use the original timing belt
I don't really know whether this is a worthwhile effort for anyone to do, as they would have to account the cost of a rebuild etc, and I think realistically 10K for the RPW 2.5 is an extremely reasonably priced engine considering the bits it has, however what really triggered this thought was that I am having my 6A12 completely rebuilt. And also a friend works in metal place where he can CNC plates and so on.
So, the way I see it for me, if I had forged out $800 for a 6A13 crank, and $1600 for custom rods, I could have had a 2.4 MIVEC.
Basically, not considering the engine rebuild cost which obviously is getting done anyway, it would be $2400 more to up the capacity to 2.4(ish).
2K for custom forged pistons and this could be a 2.6 engine.
What do people think? This is just a discussion of interested and I am not doing it, but just thinking if what came to my head is a good idea or not.
Let the arguement begin, am I an idiot or not!
PS. I don't think this is a worthwhile exercise to do if you need to pay to strip the engine apart. And I think that if you want 2.5L the RPW engine can't be beat. In fact if people add up the cost of only the parts in that engine, 10 grand is damn cheap for it
