Flushing the radiator and replacing the coolant
jakey106
Post by jakey106 »
Hey guys i need to replace the coolant in my radiator and give the radiator a good flush just wondering which is the best way to go about it.
If your a dodgy pr*ck like me, just undo the bleed valve on the bottom of the radiator & drain into a bucket. Make sure you remove your radiator cap as well otherwise the water backpressure will hold water in the system. Then I usually just undo the top radiator hose, jam the garden hose in there on full blast & start the egine for a minute! :D
