there's a comparison between a toyota camry and hyundai sonata, both being a 4-cyl 2.4L engine car with very similar exterior and interior features...
what draws my attention is as below:
hyundai sonata / toyota camry
engine : 2359cc / 2362cc
engine type : both 4cyl DOHC &WT
max power : 118.5kW @ 5800 / 117kW@5700
max torque : 219Nm@4250 / 218Nm@4000
kerb mass : 1478kg / 1500kg
tyres : both 215/60 R16
0-60 : 4.9 / 4.6
0-80 : 7.8 / 7.2
0-100 : 11.3 / 10.6
50-80 : 4.7 / 4.6
60-100 : 7.1 / 7.0
0-400m : 17.9 / 17.5
so what's special in these figures? well i find it interesting that when compare with kerb mass, hyundai is lighter than camry. compare with power and torque, hyundai is little bit more than camry. however when compare with performance, camry appears to be faster...
hmmm, so... as a conclusion, what's the significant of a dyno result? as a heavier car with a lower power and lower torque can actually go faster than a lighter car with a higher power and higher torque? and also since they're very similar in engine capacity and also they are using the same tyre size...
any comment on this??
by the way... i am no longer a "newbie" lol
