ok guess what- it sucked!! Can you believe that
Ok I did add 40 kg, but still.... but you know what, in terms of handling and responsiveness, it felt exactly like hrd2bqt's old car.. just with out the fantastic lsd and screaming to 8500 rpm bit
ok so my engine is just the 1.5, but it is usually suprisingly responsive due to the mandrel bent exhust and high flow cat I already have fitted, ready for the new engine. Spetz, I've seen you say in posts I've read that the vtecs you've driven have traction, and just 'go', where as the mitsu's spin the wheels a bit, or as hard2bqt seem to find at the strip, wheel hop. 'nightmare' I think was the term he used. Ok so suspension, tyres, tyre pressure etc. are all isues that come into play, but did you ever wonder if the reason the hondas just 'get up and go', dosn't have atleast a bit to do with the fact that they dont have a huge block of cast iron between the front wheels? I'm convinced this is a HUGE part of the problem with that blue lancer, but honestly I love that car. I just see how it could be better.
To be honest people, I agree the 6a13 frankenstein is where it's at. Spreading the 2.5 litres of displacement over 6 cylinders is just ideal. 81 mm bore x 80.8 stroke, it's virtually perfect! If you do a k24 franky, you've got a 87 mm bore with a 99mm stroke, not exactly the best for high rpm.. The 6a13 with mivec heads is theoretically perfect, except for the f*#@ing block!!!
In an ideal world, I'd have a titanium composite block, I think it's theoretically possible to produce one of them that has a relative strength to a regular alloy composite part, however instead of being 50% the weight of cast iron, it's more like 15%! But I think that one's more in the realms of racing fantasy than reality
At the end of the day, yes vtecs are great, that's being tried, tested and proven true. But think about it, there's just no challenge to it! Steph Papadakis, Shaun Carlson, all those dudes wanted to race imports because they were sick of seeing v8s run good times at the drags. It's just boring! But even vtecs are becoming boring! You can't fail with them, and because of that, there's less satisfaction when you succeed. With Mivec, you're more of an individual, it's rarer, no matter where you live. If you guys didn't feel that way, you'd probably be driving r33 gts-ts or vl commodores or whatever it is conformists drive.
At the end of the day, although speed is important, being unique and creating something noone has seen before is every bit as important to me. That's why I'm in this.
And it's not just about power- it's about power to weight! To go to the extreme, the majority of motoring journalists say the best car they've ever driven is that lotus thing that has the k20 in it, the one that weighs 690 kg or whatever it is. And that's gotta mean that these dudes think that thing is more fun than the Lambos, Carrera Gt's and what ever else. It's not that impossible to be getting as much power and torque out of 6a12/6a13 Mivec setup, if not substantially more. Eventually, you hit a brick wall with na power, even if it is a VTEC YO!!!!! and you've got 30 grand worth of JUN gear in it. The logical solution is to go psycho with weight reduction, casting an alloy block psycho, carbon fibre doors psycho. I can appreciate turbo/supercharged power, but I'm taking the na route to the top.
I can also appreciate that if people with an fto weren't already rebuilding a Mivec engine, that this wouldn't be a viable Idea, but I just thought I'd find out.
Just another point about weight reduction with na performance, everyone knows about these civics with a striped out chasis even, and there running flat 10s with just a built up b18- the equivalent of a vti-r integra engine. Another extreme example, but it proves the point. If you gonna stay na, you just gotta be as commited to shedding weight as gaining power, but that's just my opinion. Sorry for the novel.
