pulling apart fto interior
Hobbsie
Post by Hobbsie »
planning to pull out some of my interior.. the trim around the gearbox panel, trim around the aircon vents, maybe the whole centre console and some other sh*t .. to paint it red/white
anyone whos done this before.. are there any tricky plastic clips i really have to watch out for? ..would hate to break something :(
oh yeah.. i'm also going to pull out the door panels and try to remove the carpety fabric and replace it with red leather. how hard is it to get it apart?
khunjeng
Post by khunjeng »
pretty much all screws for the tip/centre consoloe. easy to take out. will take u like 20min.
shue
Post by shue »
be extra careful with the centre console. breaks really easily
<div><strong>My Car for Sale - Contact Me</strong></div><br>
Hobbsie
Post by Hobbsie »
Cheers
I aim to please...... :D
    Hobbsie
    Post by Hobbsie »
    also.. something i can't find a mention of anywhere.. to get the aircon vent trim out, do you need to pull the entire dash out, or can you pry it out with a screwdriver or something. and can i get the trim out seperately from the vent unit?
    this is the part i mean:
    Nup
    Fraid to say, screwed in from the back. Prying will only break something. Need to do the whole dash thing. I covered that in this guide......
    http://www.completefto.com.au/FTO_showcontent.asp?aid=344
    If you follow it, you should be able to work out the rest from there. Good luck!! :D
      sublime19
      Sooty!
      Post by sublime19 »
      I was told if I paint it myself, the paint will start peeling after a few months from the heat in summer etc so i rather pay a proffessional to do it since it wont peel and they'll do it properly :?
      Mine
      Mine is still looking good. Its been a good 6 months now and the bit with the climate control/clock/charge still hasnt cracked (even though it is rubber).
      Highly recommend the dashboard centre in Melbourne to anyone after a professional job.
        Hobbsie
        Post by Hobbsie »
        woah.. that paint is hot!
        also.. if you use a half decent plastic primer and good quality 2pack paint, then cracking shouldn't really be a problem.
        sublime19
        Sooty!
        Post by sublime19 »
        Hobbsie wrote:woah.. that paint is hot!
        I don't think that's paint dude, it's rubber :P
        Would be extremely hard to paint that pattern on :?
        anybody know any places in sydney that'll do the roof lining and door panels + the whole console in the middle?
        Im assuming the leatherette material can't be applied to the console and it'll just have to be painted?
        JahjaMan
        Post by JahjaMan »
        do u know if the process of removing the centre console/dash would be the same for a manual gearbox?
        Yup
        Yup,
        pretty much the same
          JahjaMan
          Post by JahjaMan »
          thats cool
          sorry, i should've asked before, but what about passenger side airbag?
          will removing the dash render it useless?
          also, i dont want it exploding unexpectedly =p
          EDIT: also, i meant if it was possible to paint the dash, and would it be ok to paint over the airbag cover?
          m3nG
          Post by m3nG »
          With all cars its usually nothing but screws & clips.. after you've taken out all the screws that you can see give it alil pull, if its stubborn then there must be another screw or two thats hidden.. Anyways.. in reguards to painting the interior i rekon that its better left stock.. If youre after a different look maybe try carbon fibre parts or something.. You'll probs get sick of the painted interior in time and wished you'd left it... Thats just my opinon anyways.. from experince that is..
          I sprayed my previous car and it looked allright.. but after a month or two kinda got sick of it.. as pictured belowed
          If you're still keen on painting it head down to Auto barn / Supercheap auto or equivalent. They sell spray paint epspecially for interiors / upholstery.. They stick pretty good without any primer... after the colors been sprayed, top it off with a "top clear coat" n that should do it.. :wink:
          JahjaMan
          Post by JahjaMan »
          wel, i was planning to do the seats same colour as middle console/speedo surround.
          and when i said painting the dash, i meant making it real black haha
          cause i wanted it to contrast.
          reckon the airbag will get in the way?
          m3nG
          Post by m3nG »
          fto's got a passenger air bag? Which yr / mod? If your afraid of setting off the air bag just pull the out the fuses, and place them back in when youre done... Im sure spraying on top of it shouldn't stop it from popping out when its needs to be..
          Liquidity
          Post by Liquidity »
          the slightest bit of static can make an airbag activate. They also hold charge for quite some time after disconnecting power.
          DO. NOT. EVER. f**k. WITH. AIRBAGS.
          that is all :P
          BorepYano
          Post by BorepYano »
          shue wrote:be extra careful with the centre console. breaks really easily
          oops, i think i came across this thread too late, right now mine is being held in place with stickers on the reverse side :oops:
