Paddle Gear Changes
Paddle Gear Changes
Just floating an idea, but would it be possible to get a steering wheel with 2 buttons, and hook each one up to the (+) and (-) of the tip part of the auto gearbox... sounds kinda cool to me, and it means you can deal with the torque steer better with both hands on the wheel at all times.
GPXXX
Post by GPXXX »
sounds like a good idea dude... i guess it can be done (don't see why not) plus it gives you the European flair too (ala Alfa 156). :D
D-TRAIN
Post by D-TRAIN »
D-Cuatro actually had a kit for this but I don't know if they still make them. Go to the Checkerflag website http://home.catv.any.jp/dd/checker/overs ... rflag.html, they have a listing for it there but it could be outdated. Email them, and ask for Teruo Miyazawa, he should be able to help you out.
The new Lancer VRX has shift buttons on the steering wheel as well (non-Momo though). If you could incorporate that, that would be pretty unique. Or if you can get the Lancer EVO VII GTA steering wheel (a Momo) one to fit, that would be even better!
Jeff
Post by Jeff »
I had thought of doing this, but what scares me is the airbag.
It would be easy to change wheels over but the computer controls the airbag and will make it more difficult. If anyone has done this please let us know.
PS Would taking off the airbag make it illeagle/
jeff
I have a '95 GPX, so no airbag to worry about :wink:
Jeff
Post by Jeff »
Then go for it.
GPXXX
Post by GPXXX »
i think frank (BLK_Jet) has tried this already.... details are sketchy atm, but will suss out more info from him... ;)
Daz_FTO
Post by Daz_FTO »
yes you can. The sensors on the tiptronic are just 'buttons' Rewire these to the buttons on a aftermarket steering wheel - like those used in fast n furious - cept their buttons were used for NOS.
On funky-fto site they have an article explaining how to swap gears on tip box...iot might be of some use. http://www.funky-fto.co.uk/gears.html
rxboy
Post by rxboy »
My brother just bought an Alfa 156 and I can see how handy these shift buttons would really be. I drive on quite a few roads with tramtracks, and sometimes I'm a bit paranoid and want to have both hands on the steering wheel :?
Daz_FTO wrote:On funky-fto site they have an article explaining how to swap gears on tip box...iot might be of some use. http://www.funky-fto.co.uk/gears.html
Yeah i saw that, that's what gave me the idea in the 1st place.
Jeff
Post by Jeff »
Supplanter,
Are you sure you don`t have an airbag. I thought all the FTO`s had one.
So by swapping steering wheels you would make the car illeagle. Yes the doing of it would be easy, but again playing with the airbag scares me.
Jeff
GPXXX
Post by GPXXX »
not all FTOs come with airbags as standard but yes, removing them would be illegal. I believe post '96 cars come with factory airbag factory as std fitment (some with MOMO wheel option)
ruchi
Post by ruchi »
Something else to consider...
When paddle gear changers were first introduced into F1 cars, there was a lot of people blowing engines. The reason for this, was in a hard turn the paddles were reversed and when they went to change up, they were actually changing down and over reving.
i.e. if the "up" lever is on the right, and you do a hard turn with the steering wheel close to 180 degrees, then the "up" lever is now on the left hand side. Pressing the right hand lever would now result in the car changing down.
Thankfully the INVECS II system will not allow you to down change to a point where you would blow your engine, but you still could be down changing when you thought you were going up, and vice versa, and in an emergency or high speed situation this could cause problems as you would be in a different gear to what you wanted.
...just something to be aware of and consider
GPXXX
Post by GPXXX »
lol, we've been tossing back and forth between 'paddles' to 'steering wheel mounted shift buttons'... hehehehe
I was thinking of mounting buttons in the centre of the wheel, through the horn button cover, near the edges... don't know if that is feasable though.
ruchi
Post by ruchi »
The title of this topic was "paddles", but yes, you would be far safer using buttons than paddles.
Make it an up / down button on one side of the wheel, rather than up on one side and down on the other.
GPXXX
Post by GPXXX »
how's this for a kick-arse idea: voice-activation! ;)
ok, enough thread hi-jack for the day LOL... :D
Blk-Jet
Post by Blk-Jet »
Been a while but i've finally gotten around to the paddle shifters.
So far i've only made fiberglass painted moulds of the paddles and rough sketches for the mounting positions, but please feel free to check out my pics page and follow. :)
http://au.f2.pg.photos.yahoo.com/ph/fra ... m=40d8.jpg
Impressive :)
A U.K guy has done it with buttons in the steering wheel, used an alarm keyfob to control 2 relays wired in parallel to the microswitches at the bottom of the gear stick, I sourced a suitable kit at Jaycar, around $120 bucks.
FTO338
Post by FTO338 »
Blk-Jet wrote:Been a while but i've finally gotten around to the paddle shifters.
I assume these mounting are for standard steering wheel & won't fit on FTO with aftermarket steering wheel?????
