Wiring
demonic_hordes
Wiring
Post by demonic_hordes »
Hi, I was wondering if anyone had a diagram of what the wiring of the woofers to tweeters in the fto were like.
when you open up the stock tweeter locations, there are wires for the tweeters. I was wondering how the connected to the woofer/hu. So a diagram that shows this would be awesome! thanks
scarecrow
Post by scarecrow »
They are connected in parrallel to the woofer, ie. the wire going to the woofer, and the wire going to the tweeter cary the exact same thing.
For instance, in the passenger door my crossover is ductaped to the bottom of the door ina plastic bag :P This one is inputted from the woofer wire. On the drivers side however my crossover is ductaped to the plastic shroud below the steering wheel and gets it input from the tweeter wiring.
And here are the factory wire colour codings:
Permanent live: RED/BLACK
Accessory +12v: BLUE
Illumination: GREEN/WHITE
Earth: 6mm nut
Antenna trigger: PINK
Rear left speaker+ : YELLOW/BLUE, Rear left speaker- : GREY/BLUE
Rear right speaker+ : YELLOW/RED, Rear right speaker- : GREY/RED
Front left speaker+ : WHITE/BLUE, Front left speaker- : BLACK/BLUE
Front right speaker+ : WHITE/RED, Front right speaker- : BLACK/RED
demonic_hordes
It works that way? you only need to connect the crossover to one of the two? (woofer or tweeter?) you don't you have to link them?
did the mitsus leave any capacitors in the wirings?
