Ok as the title mention I’ve got these baby up for grab, they been only use for 2mths.
I've since then had upgraded to OCZ Platinum version ($380 each)
So I’m willing to let these go at a dirt cheap price. Do keep in mind, they are wrapped in pure copper heat sinks which are very had to get. Most heat sinks on the market are just aluminum.
These RAM are retail for around $160-$169 each & heat sink around $15-30 each (depends what type of material). I'm letting these go for $120 each.
I've still got the original box but the RAM won't fit now since they got heat sink on, but you will have no problem installing these in your computer even if they are side by side.
2 x 1GB DDR400 Kingston RAM with Pure Copper Heat Sink(Sold)
- FTO338
- FTO338
Yes its Dual Channel. And you can use them as normal too.
Part No: KVR400X64C3AK2/2G
- FTO338
ehhehe Good enough to control NASA
Anyway these are sort of sold for $120 each, just waiting for the money to be clear.
If it falls through i let you guys know.
- Supplanter
- FTO338
Hell yeah James, those heat sink is like an intercooler, but only for RAM, so if you stick them to your FTO ECU, you get 20kw for sure
- FTO338
