My interior headlamp
vivek
Post by vivek »
A wierd problem - when i'm driving my car and turn right, my doorunlocked sign (in the dash) lights up and my headlamp (ie the lights on the rear view mirror) comes on. This happens only when i'm driving and i turn my stearing wheel to the right.
what could possibly have gone wrong????
mxysxy
Post by mxysxy »
electrical,
Damaged cable or connection?
akuma3
Post by akuma3 »
how about check the door sensor as well? i had that problem before and found out it's just a lose connection on the door button thingy
I think your left door isn't closing properly... try adjusting the hook on the door frame that the door locks onto so that it is a bit closer to the centre of the car.
Door Sensor
Definitely the door sensor. You either need to adjust your door or tighten your sensor.
    illmotion
    Re: My interior headlamp
    Post by illmotion »
    Sorry for bring this post up from the dead but where is the door sensor located? Mine been going crazy recently causing me to destroy my map light inside the rear vie
    Mirror cause I thought there was something wrong with it.
    When u open your door there is a little black button across from the back of the drivers seat in the door frame hope that helps hahaha I'll take a pic when I get home for u
    illmotion
    Post by illmotion »
    Found it thanks!, Hmm I took out the door sensor and clean them but whenever my door a open the car doesn't detect it, so my map lights doesn't work when I open the door and they can't be manually turn for some reason as well, but driving home last night my door light came on all night and my map light wouldn't turn off lol.
    Any ideas to what this problem is? D:
