Hi
I know this is not the ideal way to go about it, but i'l ask anyway.
I've got a Lanzer Vibe 238 amp, 2x 200watts RMS at 4Ohms. Wondering if can it run a pair of Infinity 6.5" component speakers 90watts rms & a pair of Pioneer 6x9's at 80watts rms.
Is it possible to configure the wiring somehow to connect the infinity to 1 channel & the Pioneer to the 2nd channel of the amp??
not keen on buying a 4 channel amp at the moment.
any suggestions is appreciated.
thanks
Lodd
can a 2 channel amp power 4x speakers?
- layzie
scarecrow
You probably could, I don't know the specifics, but regardless... don't.
Use the 2 channels to power the front splits, run the 6x9's off the headunit. Your 6x9's are only there to give some better bass to the equation, they aren't important and it's much better that your fronts are driven with as much power as you can afford to give them (within their handling abilities).
Dr_Jones
