i have just been back to sydney and found out that they have optimum extreme in shell now. Question is any of u guys use optimum extreme??
how good is it?
i am currently using normal optimax
fuel used
- AERODYNAMIST
- khunjeng
I use it all the time. all the fuss about Ethenol blends is mostly a load of bs, but if the % gets to high rubber bits start to get affected more quickly.
E5 is fine in my mind and you will notice the different once you ECU has adjusted.
I hvan't seen one piece of evidence to suggest otherwise - if you have some please forward it on pplz.
