I was wondering if the intake air valve thing is at all related to the alternator?
A friends car seems to be having a faulty alternator or dead battery, and while driving the engine light came on then off, did a error check and it came with 62, however I checked before by free revving the car and the motor off that this actually does work.
Error 62, alternator related?
- spetz
It may work off the car,but when you remove it the butterflies spring back to the incorrect position,so if you re-fit it without adjusting the butterflies back to their correct position the motor will be unable to turn bringing up error 62
