Spark Plug info
- bigpitty1
Spark Plug info
I know the FTO uses a different set of spark plugs on the front of the engine than the rear, I knoe the rear plugs are platinum tipped so they don't have to be changed as often, but is that the only difference, can I use platinum tip spark plugs all around.
You can. Only reason the rear were originally designed for long life plugs was beacuse there was no such thing as platinum or iridium plugs back in 94.... plus they are a bitch to get too. I wrote a bunch on them a while back:
Bennoz wrote:The actual sizes are identical. The reason that Mitsubishi state 2 different types is beacause of the difficulty in getting at the back ones to change them.
The only difference is that the other type specified are heavier duty & last longer. Now that Iridium & Platinum plugs have become available, you can have a plug that lasts upto 100,000kms. I recommend using Irdidium plugs all round - keep in mind that these new types of plug were not in existance when the FTO motor was designed - another reason the manufacturers recommendation is for a heavier duty normal type plug.
You can tell an NGK Iridium plug by the 'IX' being in the part number.
To me the difference between an Iridium & platinum is irrelevant as I change my plugs every 20,000kms regardless. I use BKR6EIX-11 all round. Great performance & fuel economy & they never foul up. Its worth spending the extra money on things like spark plugs - a full set for me is $110
Here's a comparison chart for you:
Nickel Alloy - Service life 20,000 - 40,000 kms
Benefits - Standard style of spark Plug.
Nickel Alloy (V-Groove) - Service life 20,000 - 40,000 kms
Benefits - Service life Improved ignitability due to sparking at periphery of the electrode
Platinum 0.8 mm dia. - Service life 100,000kms
Benefits - Long service life and even better ignitability due to a small diameter centre electrode
Iridium 0.8 mm dia. - Service life 160,000 kms
Benefits - Extremely long service life. Same level of ignitability 0.8 mm dia. Platinum
Iridium IX 0.6 mm dia. - Service life 60,000 kms
Benefits - Long service life. Same as 0.8 mm dia. of Platinum and extremely good ignitability characteristics. (Better than 0.8 mm dia. platinum or 0.8 mm dia. iridium)
- khunjeng
some1 suggested but the normal NGKs in on the front...I said no...although he did it anyway...just put the good ones all round...don't mis match...Craig from revzone is gonna give me some slightly different plugs he reckons are really wicked...colder I think..not sure about the exact specs...but they r a version of the platniums I think
but i remember last time i change my spark plugs i need special key to get into the hole right? i need to place mine again, any suggestion on who have the key to service my car in sydney?
Bench Grinder
I did a angle grinder job on one of mine too. You just have to keep taking a bit off till it fits!!!Nothin' you cant do with an bench grinder mate
