Where to wire a relay?
Hey guys,
i changed my fog lights to higher wattage globes which inturn burnt out the foggy button which cant handle the high current. Gotta new buttton now and a 40amp 12v relay. Has anyone wired a relay for this yet??
Can anyone tell me where i need or can wire it from??
im know i need to run a new power source to the relay, what kinda fuse would that need?
regards mick (lanyon)
- kazbah
- National Secretary
- Blasphemy
I used two parts both available from your local dick smith. A standard 12v auto relay and a wiring harness. The harness isn't required, but it costs bugger all and makes the job neater and easier. Total cost of parts $8.43.
Available here:
http://www.dse.com.au/cgi-bin/dse.store ... View/P8036
http://www.dse.com.au/cgi-bin/dse.store ... View/P8035
The problem occurs when you're trying to put lots of current through a push button that's not rated for it. The solution is not running the current through the push button. This is where the relay comes in. The relay uses the smaller current to complete the heavier circuit. (If that makes sense.)
When the switch is pushed, there's a pair of wires that complete a +12 circuit. By running that pair of wires to the relay, you tell the relay to complete the heavier power circuit for the lights. No need to run any additional wires.
I've written a vague description of the pinout here http://www.ftoaustralia.com/modules.php ... pic&t=6827
I'll take some pictures soon when I pull my dash apart, again.
Available here:
- Nacho
Aren't the foglamp bulbs sealed inside the cluster?
Would it make any difference if you replaced the globes using the new HD globes with the same wattage as the stock bulbs?
I'm on my 2nd switch and it's not liking my fog lamps at all. I never changed em though since I had the car so someone must have replaced them prior to my purchase.
- Blasphemy
So here it is...
I know I should have taken everything apart and told you which wire connects to which number on the relay, but I got lazy so you're just going to have to buy the wiring harness and refer to the colours.
Wiring harness -> Car wiring
green -> red w/silver band
black -> red w/silver band and black stripe
red -> green w/white stripe
white -> black w/yellow stripe
blue -> unused
Disclaimer: I'm not saying this is the right way to do it, but it's the way that I've done it and it works.
The red with silver bands are the fog light circuit. If you were to connect those two together, they'd turn the lights on. You can simply cut those two off the switch connector. The other wires should be spliced.
If you'd like the fuzzy awkward pictures send me your email address because I don't have any hosting at the moment.
Best of luck.
blue -> unused
Best of luck.
got the relay working today and this is how its wired(for pics send me your email)
relay pin# wire colour
85 red w/silver band black strip(+)
86 red w/silver band(-)
30 green/white strip(+)
87 black/yellow strip(-)
for pins 30 and 87 the wire remains connected to the loom but spliced off to its respective pin.
** WARNING wiring this way allows the fog's to turn on and off when your parkers and low beams are off, BUT the fog lights will always come on with your parkers and low beams which is what i always turn on anyway, wiring this way u will not be able to turn them off while your parkers and low beams are on******
No need to run extra wires or fuses.
- SchumieFan
Re: So here it is...
Thats what i did.... bad idea, the foggies arnt nearly as bright as they used to be.... so i added another 2 lights to try and boost the light.... bad idea! is that smoke comming from my steering wheel??? some pink wire on the colomn was getting very hot... luckily no damage. and this only happened when the lights were on so i just didnt have the car out at nite... i now have just completed the whole wiring circuit from the switch in the dash to the new lights in the front and have the stock foggies running off the parklight circuit.... no change in brightness in the foggies theyre as bright as ever.Blasphemy wrote: The red with silver bands are the fog light circuit. If you were to connect those two together, they'd turn the lights on. You can simply cut those two off the switch connector. The other wires should be spliced.
BTW the new lights... i kinda upgraded the bulbs to 135W.... i spose running 6 bulbs.... 8 if your greedy off of 1 little wire then i spose yeah it was a bit of a big ask.
learn from my mistakes.... please
- Blasphemy
If you run lights that draw more power than the standard wiring is meant to allow, you might melt the wiring or start a fire if the line's not fused. Adding more lights would only worsten the situation. The only way the fog lights would be dimmer is if the relay isn't rated high enough. The standard relay is 30A which should be fine for most fog bulbs.
Beep sound when you turn the lights on
Hi there guys,
Just got my FTO today and i believe that there used to be a 'beep' sound (the same that should come on when you open the door with the keys in!).
Mine does not do this and i am wondering how this is enabled again (probably a cut wire or the like).
I would also like to add the above mentioned relay to my switch, it is working fine but i am yet to investigate what voltage globes are being used in my foggies.
Also if i can get some hints on the usage of the aerial switch. Mine does not do anything at the moment and i am interested in the correct functionality of this. My aerial is at half mast permanently..
look forward to your responses
