Earth Wire & Voltage Stabilizer
Is anyone using it at the moment? Can you notice a difference? Basically i want to reduce the electricty usage so just wondering what's the best way to go.
May make a minor difference but generally the effect is negligible unless you have poor grounding in your electrical system already.
For the price of a kit you're better off buying some large gauge cable and upgrading the factory earthing points on your car - eg battery negative terminal, alternator grounding, etc.
- FTO338
MrFT000 wrote:will this stop me from getting zapped everytime i get out of the car?!
hahahah sounds like Grant been doing some "lovin" in his ride ahahahapayaya wrote:getting zapped it more to do with the fact that your building up static when driving.
- Nacho
Hahaha everytime he get out of the car!
Seriously though do we have a DIY on how to fit an earthing kit on this site? Can't seem to find one using the search. From what you told me Kev it's only about $50 bucks isn't it?
I really did love that high pitch sound from my head unit when I accelerate.........hehehe
- khunjeng
How is your head unit earthed...? I remember in another thread I had an arguement about this...anyway to be safe I would earth the unit directy to the body..if you take out the centre console there is a great spot on a bracket to use...if the noise is still there (which I have never had when been earth correctly in all my cars and I've installed a number of them) you can get an inline filter/supressor for these noises (although I have never used one).. however this is a little of topicNacho wrote:I really did love that high pitch sound from my head unit when I accelerate
- ahew
the earth/ground wire is for safety. it is used to ground metal parts of any electrical device so thay can't become "live" (dangrous to touch) if the power wire decides to come loose.
as for the whirring sound, normally it's caused by the power line running too close to the speaker wire/rca. when the power runs through the power line it creates a small electromagnetic field which can disturb the information in the other wires close to/around it. hence the whining type of sound when you press the accelerator. whenever i setup my cars i make sure that the power line runs through one side and the speaker wiring/rca cables run through the other side.
- khunjeng
no earth or GND = no circirt = OFF.ahew wrote:the earth/ground wire is for safety..
You really wanna know whats causing your interference read this...however its quite complex...I have studied electro mag. and Quantum Physis so i understand...however it basically starts the main sources of noise from your car...
http://www2.arrl.org/tis/info/pdf/001qex32.pdf
Ahew has a good point however this is only 1 of many sources...Read the following link carefully... note they suggest a decent earth to the chasis for engine noise..
http://www.crutchfieldadvisor.com/ISEO- ... noise.html
- SchumieFan
anywhere it will earth basically, i screwed mine into the last screw on the stereo bracket as i forgot to earth it when i had it out.... came to put the thing back in and "hello.... i have a loose wire.... ill just put this here then"
works fine
but i need to ground my headlights better now i have 8 (10 if u count the park bulbs) headlights now, low beam, high beam, factory driving lights, and added driving lights (to help me see round corners(135w!))
so yeah, blown a few fuses, and i know im not getting the most from all the lights, anyone would think i have them in series not parallel!
what was the topic? oh yeah, grounding is important.
works fine
