hey all bro.i just wondering do u guys know any place servicing car?i would like to take my fto go to service.coz the engine has to service on 124300kms.so any suggestion in sydney?prefer the price is reasonable and not so expensive.provide the address too please.thanks.
by the way,do u guys know how much service fto and the engine as well.thanks
servicing
- beckham5000
Most people go to UAS in sydney. Its not cheap but at least you know they work on ftos regularly and they will do a good job. Their website is www.nismo.com.au for address...
no one can predict the cost of your service - it depensd on what they want or need to do.... if its just oil and filter changes it will probs be around $150-$200?
- APZ-312
servicing
Maytech Automotive also does a pretty good job. They're located off the princess highway in arncliff.
Reasonable prices too. They work on a couple of fto's from what ive seen at the workshop and also have done a great job on my car.
Just had my 100k service done there.
- smorison
- The Godfather
full details here: http://www.nismo.com.au/service%20general.htm
UAS General Service price is $220.00
and includes the following parts and labour:
Thorough check of your vehicle and report supplied, including:
Check all fluid levels
Check exhaust system
Check suspension system
Check all drive belts
Check and adjust the idle and mixtures as required
Report on your brake level (% of worn brake pads given)
Check all tyre pressures
Check all lights
Washer jets adjusted if required
Washer bottle topped with cleaner fluid
Coolant condition checked
Engine oil "10w/40"and filter changed ( we use Motul 4100 synthetic type)
OEM or Japanesee made oil filter - whichever is better
Performance air filter cleaned and oiled (Extra $15)
Engine cleaned underneath
Clean and treat battery terminals, door hinges, bonnet and door latches
Road tested
General Service Extras - (If required)
Quality Bosch fuel filter or OEM ($40) - We recommend changing every 25,000 Km's
Coolant premix Motul - as in distilled water ($7.90 a litre - No harmful tap water used here at UAS)
Motul ESTER Base 300V (extra $7 per litre)
Redline Shockproof Synthetic gear & diff oil ($30 per litre - great for gearboxes with worn synchros)
Motul brake fluid dot 5 synthetic ($19.95 per 500ml bottle. For a full flush, max 2 bottles required - this is often neglected
Consult data scan for 90 models and above for Nissan, Toyota, Mitsubishi and BMW ($40)
Road test air fuel ratio ($50.00)
Quality wiper blades ($8.00 each)
Air filters if required
Spark plugs (We often recommend the use of the all new Iridium NGK spark plugs - $18.50 each plus labour to remove and fit)
(click here to find out more about the all new Iridium IX spark plugs)
Additional Service Options
Engine flush (Wurth brand) $15
Radiator and engine flush (Wurth brand) $15 plus coolant and extra labour
Systems clean of throttle body(s), vaccum lines and PCV etc as well as plenum chamber and top of valves etc (pressurized cleaning liquid sprayed
into throttle bodies and plennum chamber with car running to strip carbon build up) good for turbo cars especially as they often run rich and can
choke up ($50.00 including labour)
On car injector clean ($95.00)
Car clean inside and out ($40.00)
Power run on Dyno ($80.00 - Check out the Dyno centre for more information)
remember these are "web" prices... they are normally flexible
Check all lights
Road tested
- Boris
Re: servicing
I can vouch for Mayan, I haven't had my car serviced by him, but Jono is really close to him, Mayan proably has pulled apart Jono's FTO a few times now. I go up to wakefield with Mayan and he doesn't do dodgy work, and he is a nice guy. Price will be probably cheaper then UAS aswell.APZ-312 wrote:Maytech Automotive also does a pretty good job. They're located off the princess highway in arncliff.
Might be worth while you checking it out if it is closer to you..
Boris
- APZ-312
servicing
yeah mayan's a top guy. i saw his red fto he takes up to race at wakefield.
apparently he's been getting noticed a lot from major wholesalers cos of his win at a championship recently.. which is really good news for me cos den i can get parts for much cheaper thanks to him lol
was gna get my lifters replaced.. all 24 of them and he's lookin out for some after the holidays.. says he can get em cheaper than $18 a piece.. im impressed..
but yeh.. he does really good quality work and very reasonable prices.. wont skim round d edges.. u get more den what u end up payin for..
up to you watever is close and what u prefer ofcourse =P
