RPW - Throttle Body Upgrades & Fuel Pressure Regulato
khunjeng
Post by khunjeng »
Has anyone bought the FSE Fuel Pressure Regulator and/or Throttle Body Upgrades from RPW?
Looking for some feedback on their performance/suggestions.
KJ
FTO338
Post by FTO338 »
Barfy has, & he did a review of it already
RedlineGX
Post by RedlineGX »
I got both. basically FPR no difference in performance but I think it makes u run a little richer so if you want to get other mods you can without the worry of leaning out.
The 65mm T/B I have on does feel better however I put it on before my extractors and I have to tell u dollar for dollar the extractors are way better but I suppose working them together is the key.
barfy
Post by barfy »
Yep i would definately recommenned getting the TB/Manifold and the Extractors together... The FPR is needed because running the extractors without it, the car runs rich...
Also to get full advantage out of these parts you would need some sort of ecu piggyback... I should have the Greddy Ultimate installed sometime after the new year...
[img]http://i142.photobucket.com/albums/r103/barfy76/barfycopy1.jpg[/img]
khunjeng
Post by khunjeng »
thanks fellas
The plan is to get the RPW TB/Manifold FPR and the Extractors including a high-flow CAT and new tail pipe / muffler.
KJ
smorison
The Godfather
Post by smorison »
you can save money by getting your local performance shop to take off your TB had have it done...
should only cost you about 150.00 or if you have the right contacts you could get it machined yourself and save even more money... only thing to remember is that you need a new butterfly but they can be machined up really cheap as well.
the FPR you can buy anywhere as well, and if your mechanically minded enough fitting it is a piece of piss
khunjeng
Post by khunjeng »
thanks for the info...matters what mood I'm in when I doing it...I have some1 who can do it and they want to also polish/port the heads during the process...my guess is that with all of that done...its should be sweet as!
shue
Post by shue »
hey khunjeng could u let me know when u get it done and from whom. coz im looking at getting work done on the tb/mainfold as well as port/polish heads. thanks in advance :D
