Optima Battery model
akuma3
Post by akuma3 »
Does anyone know which model will suit FTO for yellow top deep cycle? :o
Breza
Post by Breza »
Hey,
I have a yellow top Optima...............
Not sure of the model designation but if you measure your old battery there is a yellow top that is nearly exactly the same size. (1 or 2 cm taller from memory)
Be warned that you will need to change your battery clamps to suit as the Optima has different sized posts to standard.
Cheers
Chris
akuma3
Post by akuma3 »
yeh i just figure that out, i need to change the clamp :x
which model r u using?
