car is idling way to high
TFS
Post by TFS »
Was 3 days ago my car started idling at 2500rpm when it normaly idles at less then 1000rpm.
i tried reseting everything via disconecting the battery and even had a play with the accellerator wire but didnt solve anything.
anyone with any help on this please? saves me taking it to a mechanic.
thanks
Do a search (using the button above the forum not the one to the left) for idle problems. You'll find numerous threads & with the same problem & resolutions.
in drive as well its at 2k? Turn the idle down a bit via the idle screw on the throttle body.
Do you have cold start problems?
When you turn on the AC does the revs drop or rise?
