Steering Wheel Shakes
akuma3
Post by akuma3 »
Just a simple common question, why does my steering shakes when it gets up to 100+, i did wheel aligment so i'm sure it can't be that, what could be the problem because i know all old cars do that?
Wheel Balance
Wheel Balance is what you're after...
    akuma3
    Post by akuma3 »
    and i did that as well, what could it be? :?
    tarkus
    Post by tarkus »
    it could be that the tyre is not aligned properly or the whell is buckled.
    try spinning the wheel on the car and check that it is running true.
    Also check for a damaged tyre.
    try swapping the fronts to the back and see if it still vibrating, if not keep looking at the wheels / tyres.
    Cya Tarkus
    Disc rotors may need machining too... do you get any vibration from the brake pedal when applied at that speed?
    akuma3
    Post by akuma3 »
    new rims new tyres ... wheel alig
    from braking only squeeeek noise probably because of my brake pad, but no vibration
    how long does a wheel balance last till it just wander off again?
    Jase
    Post by Jase »
    Depends on who did the balance. though with new rims etc you'd think it would be ok. Maybe one or more of the weights has come off. Wheel bearings maybe?
    www.racingspec.com.au
    akuma3
    Post by akuma3 »
    well, any suggestion for a place to do wheel balance in sydney? 8O
    yeah will be a balance for sure. In my opinion always go to say Beau Repairs etc for a wheel balance they always do a top notch job.
    If that fails check your steering rack.
    akuma3
    Post by akuma3 »
    payaya wrote:yeah will be a balance for sure. In my opinion always go to say Beau Repairs etc for a wheel balance they always do a top notch job.
    thanks for info everyone, i'll do that again .... this time i'll give to some pros
    akuma3
    Post by akuma3 »
    just did a wheel balance but it's shakes, comes to think about it i start shaking after i change my steering wheel ... how could i fix it? :?
