strange electrical problem
i have a gr 95 fto and when i installed a new stereo head unit, their seems to be in electrial running through it, my reading lights are also not working and there seems too be no door light when i opened the doors as well...[/b]
- SchumieFan
- khunjeng
- SchumieFan
- SchumieFan
- khunjeng
The origional FTO lume does not contain an earth - hence some1 has added yours to use an aftermarket head unit..like we all have.
A bad earth can cause similar problems to the ones discribed and can easily cause a fuse to blow..
- SchumieFan
- khunjeng
mine didn't...why? cos this is the std lume wiring for an FTO:
Permanent live: red/black
Accessory +12v: blue
Illumination: green/white
Earth: 6mm nut
Antenna trigger: pink
Rear left speaker+ : yellow/blue
Rear left speaker- : grey/blue
Rear right speaker+ : yellow/red
Rear right speaker- : grey/red
Front left speaker+ : white/blue
Front left speaker- : black/blue
Front right speaker+ : white/red
Front right speaker- : black/red
I can't be bothered going into the detail of why a bad earth will effect other things like lights etc...but it does...although I have no idea if this is the actual problem
Earth: 6mm nut
Actually I’m intrigued as to how one component with a bad earth can cause another to fail, even though on the same circuit. Do tell as I could learn something. Sorry if I sound like a smartar$e that’s not my intention.
There's no circuit if there's no earth but why does that stop the lights or cause the fuse to blow? Wouldn't there need to be a circuit to blow the fuse?
- ahew
