The Rain's pissing in!
gort
Post by gort »
Hi Guys.
I know it's not a common thing over there but
It's coming in from under the dashboard (passenger side) running down a seam in the corner.
carpet soaked 8O
is there any usual suspect area's I should be looking at.
"Gort...Klaatu barada nikto"
[img]http://s238.photobucket.com/albums/ff78/kk99ll/th_ftobuZZ.jpg[/img]
ahew
Post by ahew »
you've posted in the wrong section gort :)
FTO338
Post by FTO338 »
Fixed :wink:
Breza
Post by Breza »
Is the water smelly/oily?
How about the heater core? (The heater box etc are located behind the dash on the passenger side.)
Cheers
Chris
small chance
This is probably a small chance, but make sure all the firewall grommets that cables pass through are properly seated. If not this then I would definitely be looking inside the car for the source - Its probably originating from your radiator in some fashion - are you losing water???
    Dr_Jones
    Post by Dr_Jones »
    Check this out it could be the same thing I had going on, provided you are using your air con.
    http://www.ftoaustralia.com/modules.php ... highlight=
    gort
    Post by gort »
    Thanks for the info Guys
    Defiantly water from the outside
    80% certain it's below the windscreen in the corner round were the hinge is
    gort
    Post by gort »
    Fixed it :D ( I hope )
    Chiangstar
    Post by Chiangstar »
    i was gonna suggest that it may have been something pinching your door seals...
    what did it turn out to be?
    simon
    "for relaxing times... make it Suntory time..."
    gort
    Post by gort »
    simon
    Garage traced it from were the ECU is bolted to the near side front, up to the corner of a seam near the windscreen, it's lucky I had cut out for the dash speakers last year, because he would'nt have had the view as seen in the pic
    have'nt put the carpets back yet, I'll wait till it rains so to give it real test
    He's also had the hosepipe on it non-stop for 15 minutes and there's no sign of it leaking
