help regarding ECU code
- joey
can any help me to find out what this code mean
SCI fail
SCI relay fail
DCC system fail
this morning i had my fisrt service on the car since i brouight it one month ago
SCI fail
SCI relay fail
DCC system fail
CODE ITEM
11 Oxygen Sensor
12 Air Flow Sensor
13 Intake air temperature sensor
14 Throttle position sensor
15 ISC Motor Position Sensor
21 Engine coolant temperature sensor
22 Crank angle sensor
23 Camshaft position sensor
24 Vehicle speed sensor
25 BARO Sensor (listed as 26 in one info source)
31 Detonation sensor
32 Vacuum sensor
36 Ignition Timing Adjustment Signal
39 Oxygen Sensor
41 Injector system
42 Fuel Pump
43 EGR
44 Ignition coil and power transistor unit (Cylinder 1 & 4)
52 Ignition coil and power transistor unit (Cylinder 2 & 5)
53 Ignition coil and power transistor unit (Cylinder 3 & 6)
55 Idle Air Control Valve/Servo Valve Position Sensor
61 Communications wire with A/T-ECU
62 Intake air control valve position sensor
64 Alternator FR terminal
71 Vacuum control solenoid valve (TCL)
72 Ventilation control solenoid valve (TCL)
Coil pack is shot..... middle cylinder
11 Oxygen Sensor
12 Air Flow Sensor
32 Vacuum sensor
39 Oxygen Sensor
41 Injector system
42 Fuel Pump
43 EGR
Ok, found em...
Automatic transmission - Chassis manual section 23
With a flashing N lamp there are two possibilities of what it could be.
If it flashes at 1Hz, once a second, then it will be either,
Input speed sensor
Output speed sensor
Solenoid valve
Out of phase at shift points
A/T control relay system
If it flashes at 2Hz, twice per second, the ATF temperature is too high and you should stop to allow it to cool down.
11, 12 and 14 all relate to Throttle position sensor system (Vehicles without TCL) and Accelerator pedal position sensor system (Vehicles with TCL)
Code
11 Short circuit
12 Open circuit
14 Sensor maladjustment
15 Oil temp sensor system Open circuit
21 Crank angle sensor system Open circuit
22 Input shaft speed sensor Open/Closed circuit
23 Output shaft speed sensor Open/Closed circuit
26 Stop lamp switch system Short circuit
31 Low and reverse solenoid valve system Open/Closed circuit
32 Under drive solenoid valve system Open/Closed circuit
33 Second solenoid valve system Open/Closed circuit
34 Overdrive solenoid valve system Open/Closed circuit
35 Reduction solenoid valve system Open/Closed circuit
36 Damper control clutch solenoid valve system Open/Closed circuit
41 1st gear ratio does not meet specification
42 2nd gear ratio does not meet specification
43 3rd gear ratio does not meet specification
44 4th gear ratio does not meet specification
45 5th gear ratio does not meet specification
46 Reverse gear ratio does not meet specification
51 Abnormal communication with Engine ECU or Abnormal communication with TCT ECU
52 Damper control clutch solenoid valve system Defective system
54 A/T control relay system Short circuit to earth/ open circuit
56 N range lamp systems Short circuit to earth
71 Malfunction of A/T ECU
Unfortunately I know very little about the tips - being a manual owner. But it sounds like that shot soleniod would cause the communication error. Then again, it could be something as simple as a ripped wire... you bottomed out on anything lately?
Input speed sensor
Output speed sensor
Solenoid valve
Code
11 Short circuit
12 Open circuit
- joey
- SchumieFan
