How do you fit 6x9s at the rear
- GPXXX
ok i'm contemplating on replacing the factory 6x9s on the FTO's rear parcel shelf...
i had a good look at the parcel shelf and speaker mounts but i still have NFI how to remove that speaker mesh-thingie...
HELP!!!
HELP!!!
- rxboy
LOL.... I was trying to do the exact same thing a couple of days ago. Tried to use a screwdriver to go under the speaker mesh and lift it up, but couldn't do it. Maybe the only way to get to them is from the boot. My speakers are clearly visible/reachable from the boot and there's nothing covering them. Is that the way it's supposed to be?
Has anyone installed good 6x9s in their FTO? I've decided not to go for the sub because of how much room it will take up in the boot and because it will cover up access to the space-saver spare. I assume you can get pretty good bass from them, especially since the boot will act like an enclosure for them.
- Theremin
- rxboy
- NightFire
- rxboy
I might get Alpine Type S 6x9s. They seem to have a better frequency response than their supposedly superior Type R counterparts. For some reason most 6x9 speakers include a tweeter (coaxial 2-way). That would be pretty useless in an FTO considering that we have tweeters directly pointed at us from the front vents.
Does anybody have any experience with JL Audio speakers? I know their subs are good but not sure about the speakers.
- GPXXX
- rxboy
- GPXXX
- Quattro
6x9 speakers aren't as good as they are cracked up to be.
If your buying Alpine, better bet would be to buy 6 1/2 inch for rear shelf and a sub for bass with small V12 amp to run them. Cleaner bass and you get the benefit of better mid range, which leads to better all round package. Add some 6 1/2inch speaker with splits at the front and all sweet. Balance of treble, mid-range and bass.
TheSentry
We have tweeters?rxboy wrote:That would be pretty useless in an FTO considering that we have tweeters directly pointed at us from the front vents.
The previous owner replaced all the stock speakers with Kenwoods and they do use quite good, but they r running off a cheapo deck that only puts out 25w per chan. I was hoping someone would steal it to give me an excuse to replace it, but it doesn't look like that's gonna happen.
- Daz_FTO
- smorison
- The Godfather
- elmo
tweeters
mines got tweeter in the door too. Must be non-factory.
BTW GPXXX you gotta drill out the pop rivets holding in the mount for the baby seats that should have been fitted when the car was complianced. Took me a while to figure it out, but cant be done without taking the mount out.
Got 6x9 JBL's, two ways I think from memory, cause I got the tweeter etc in the front.
- rxboy
- rxboy
